Very nice....I plan on swapping my pads out with some ceramics for less dust as soon as I get around to it....
Does anyone know if the pads are the same for the 2015 f sport as they are for the 2014 or did they change them...I was trying to look them up on autozone but they didn't list any for 2015
I used the shims that came with the pads, no anti squeal. No I didn't resurface rotors as I will replace them soon. Did not bleed brakes, nor did I change fluid. Just had it flushed
The 2013-2015 front FSport brake rotors and pads should be the same. Maybe even the 2016 will use the same parts too. I don't see why would they change it, these are basically the exact same cars.
I just got my front brakes replace on my GS350 F Sport. I notice that my rotors has a lip at the end and after the shop resurface my rotors the lip was gone. I didn't want to spent an extra $600 for the pair of front rotors and I wanted my rotors to be resurface. Is this normal to have a lip or not?
On worn brake rotors you will often see a lip on the outer edge of the rotor that is created because the brake pad does not contact the entire rotor surface, so as the rotor wears down this leaves an outer lip on the rotor. Your rotors were resurfaced on a lathe to remove some of the rotor's surface in order to smooth the entire rotor surface, which in the process removed the lip on the outer edge.
