led light replacement guide?
Old 02-21-16, 07:16 PM
supra725
supra725's Avatar
Default led light replacement guide?
hi guys..
I'm in the midst of replacing all the halogen bulbs on the car..
so far i have done the door light with led bulbs but I need some help with the others..
Turn Signal Light Bulb Rear is 7440.
Turn Signal Light Bulb Front is 7444NA
Vanity Mirror Light Bulb Is 175
Reverse light is 921
which led upgrades did everyone used? for the turn signal light front.. I would need amber ones correct? do i need amber ones in the back also??
and the biggest question.. what's the size for the puddle lamp? i looked at sylvania but can't find the puddle lamp one? i want something that's bright.. the halogen ones in there are just way too dim.
thanks
Old 02-21-16, 11:47 PM
dchar
dchar's Avatar
For the rear turn signals, many on the NX forum have swiped their 7440 bulbs for these LED ones. They don't require resistors and don't hyper flash. I assume it'd work for the GS too. I'm considering doing this change too.
http://store.ijdmtoy.com/No-Resistor...0-02x-cree.htm
For the reverse lights, I ordered and installed these bulbs. They are much brighter than stock.
https://www.ebay.com/ulk/itm/351104541822
Old 02-22-16, 05:25 AM
supra725
supra725's Avatar
What about the puddle lamp? The one on the side mirrors?
Old 02-22-16, 05:42 AM
Davenlei
Davenlei's Avatar
How close does the new bulb get to the reverse light lens since it is a longer bulb than the stock bulb by 0.2"
Old 02-22-16, 07:09 AM
dchar
dchar's Avatar
There was no fitment issues and I think there were still a few inches between the bulb and lens.
Old 02-23-16, 05:51 PM
faifai83
faifai83's Avatar
That is a T10 bulb
Old 02-24-16, 07:09 AM
AJLex19
AJLex19's Avatar
Received 1,168 Likes on 863 Posts
I used a 194 bulb for the puddle lamps from vleds with the 5000k color (http://www.vleds.com/shop-bulb-numbe.../360/6-5k.html).
Depending on your taste, you might want a bulb for the puddle lights with more blue in it (go for the 6000k in this case).
Old 02-24-16, 09:00 AM
bigblack06
bigblack06's Avatar
I used these bulbs for my puddle lights and found them to be really bright.
http://www.amazon.com/SYLVANIA-2825-Premium-White-Miniature/dp/B00AIJY2ZM/ref=pd_sbs_263_4?ie=UTF8&dpID=41QMN8wJZsL&dpSrc=sims&preST=_AC_UL160_SR160%2C160_&refRID=17CWX9G0Z2WE3AMVKF0D http://www.amazon.com/SYLVANIA-2825-Premium-White-Miniature/dp/B00AIJY2ZM/ref=pd_sbs_263_4?ie=UTF8&dpID=41QMN8wJZsL&dpSrc=sims&preST=_AC_UL160_SR160%2C160_&refRID=17CWX9G0Z2WE3AMVKF0D
Old 02-24-16, 11:47 AM
Davenlei
Davenlei's Avatar
How much space was in the puddle lamp housing if I wanted to go with a slightly longer CREE 194 bulb.
Old 02-24-16, 07:06 PM
AJLex19
AJLex19's Avatar
There was definitely some room in the housing to put a longer bulb but I don't have exact dimensions. The VLED bulbs I used are definitely longer length-wise than the standard halogen 194 bulbs they used from the factory. I've used both iJDMToy bulbs in my previous IS 350 (http://store.ijdmtoy.com/2W-T10-2825...s-p/10-300.htm) and now VLEDs in the GS puddle lamp housings with no problem.
I highly recommend any of the 194 bulbs from either one of these manufacturers but I give a slight edge to the VLEDs for quality.
You may be able to get a better idea as to the housing/space from images from the following thread: https://www.clublexus.com/forums/gs-...light-led.html
Old 02-27-16, 05:38 PM
supra725
supra725's Avatar
big black,
would you have any output pics for the puddle lamp?
Old 02-28-16, 03:19 PM
bigblack06
bigblack06's Avatar
big black,
I will when I get my car back from collision center.
Old 03-01-16, 08:23 PM
AJLex19
AJLex19's Avatar
Here are a couple of output pics of the VLED 5K 194 LED bulbs in the puddle housing (looks better in person!):
Old 03-02-16, 11:55 AM
zerocypher
zerocypher's Avatar
I'm looking to swap some of the stock bulbs with LEDs too. A comprehensive list of each bulb and suggested replacements would be great. I'm sure the rest of the community would want this stickied. Keeping the OPs list going:
Puddle light is 194
Turn Signal Front is 7444NA
Turn Signal Rear is 7440.
Vanity Mirror Is 175
Old 03-02-16, 01:05 PM
supra725
supra725's Avatar
Thanks bIgblack.
Aj,
would you have the link to the bulbs you purchased? was it hard to replace?
Quick Reply: led light replacement guide?
