Hi Does anyone know how to remove rear bumper i need to replace my exhaust duct since i bent mines?
You need to take your rear wheels off, to get to the screws inside the wheel wells on each side. Then open your trunk and on the left and right side of your bumper you will see a small circular plastic covers, you need to pop those. There will be a screw inside.
I think that's it, you'll just have to pull it off the car gently.
No need to take your wheels off... just lift rear up, wheels get down to make some room for screw driver or 10m socket (slightly bend fender liner to reach it), also there are 4x plastic clips on the bottom of the bumper, plus 2x 10m bolts that SNiiP3r mentioned when you open a trunk (remove plastic covers first)
