Carbon Fiber Interior Trim!!!
Old 04-06-16, 04:05 PM
  #61
navleu
navleu's Avatar
Bossles I like it, it looks pretty good. I may do this in the future, but I am curious, how was the knifeless tape able to help you in this application which such tight edges. Where able to use it. Thanks
Old 04-06-16, 04:29 PM
  #62
Bossles
Bossles's Avatar
I did not use knifeless tape for trim. Cleanly apply vinyl and make sure to clearly define all edges. Then cautiously use blade to cut. You don't need to apply a lot of pressure. The "guide" of the gap is where the blade would pass through. Takes a little time but no damage done.
The true safest way was to take completely apart. Doors I just layer over and cut. Same with rear console accent.
Old 04-11-16, 06:58 AM
  #63
Sevn86
Sevn86's Avatar
Thanks for posting pics y'all. I'm definitely doing this soon.
Old 05-09-17, 06:27 PM
  #64
badman5
badman5's Avatar
How did you remove the passenger side trim above the glovebox?
Old 05-10-17, 09:34 AM
  #65
Bossles
Bossles's Avatar
I did not take that piece apart. I placed the material over and used a heat gun (or blow dryer) to help define all the edges with a dull plastic tool. Make sure you take your time. Once all edges where clearly defined and material is set on the area, get a blade and softly cut away. Cut gently so that you do not damage the accent or the dash.
I do believe complete removal would have been safer, but it got the job done.
I tried to take it apart prior and couldn't figure it out... so I did it this way.
Old 05-10-17, 09:55 AM
  #66
DaSyce
DaSyce's Avatar
You have to remove the glove box, there are screws holding it along with clips.
  #67
shurik74
shurik74's Avatar
It's a hassle to remove this piece... glove box need to be removed and screws holding this piece facing towards firewall.
Old 05-10-17, 11:28 AM
  #68
badman5
badman5's Avatar
Thanks DaSyce & shurik74, i unfortunately tried taking it off by starting at the vent and now i cant put it back without removing it.
SO i have to remove the entire piece, at which point i will properly wrap it. I'll take pics and post them if i can figure it out.
Old 05-12-17, 07:46 PM
  #69
badman5
badman5's Avatar
I removed the passenger side trim.
To remove the right side passenger trim, you first tneed to remove the glovebox.
There are two nuts/screws on the bottom, one on the left near the center of the car and one on the right near the door.
Then 2-3 (i forgot) screw on the top inside when u open the glovebox. once the screws are removed, pull it away with the clips.
Then you need to remove two screws from the inside that hold the trim and right vent assembly.
Lastsly remove a cable by pressing the clip on the right airvent.
Pics of wrapped trim below.
2014 GS350 right passenger side trim removal
Old 05-15-17, 11:51 AM
  #70
PsykotiK
PsykotiK's Avatar
Images of driver door trim that was damaged by seat belt. Up close, no more damage/dent showing.
there is a tsb to have the front door trims replaced for free
Randre19
Chicago Lexus Club
10-02-14 10:30 PM
PYSpeed.com
Club Lexus Vendor Marketplace
24
07-25-13 04:10 PM
Cranbery
SC- 1st Gen (1992-2000)
33
10-08-12 09:42 AM
Chachiiis
18
04-25-12 04:29 PM
SC400DRFT
50
04-27-08 08:53 AM
Quick Reply: Carbon Fiber Interior Trim!!!
