Wheel setup advise 9.5 +22F | 10.5 +22R Help
Old 08-03-16, 06:44 AM
kydoshin
kydoshin's Avatar
Default Wheel setup advise 9.5 +22F | 10.5 +22R Help
Hey guys,
I'm looking to get some Volks ZE40:
9.5 +22 Front 10.5 +22 Rear
Does anyone here know or can chip in on these offsets...if they will fit on a GS Fsport? I've searched around but haven't seen these offsets on a GS. Seen some fit on the IS-F.
What kind of fender mods will be needed. (most likely will be needing camber arms)
Any info/advise will be greatly appreciated! =)
Old 08-03-16, 08:53 AM
LexRuger
LexRuger's Avatar
You'd need mid to low 30 offset in front and mid to high 40s in the back.
I don't think I've seen anyone here run offsets in the 20s unless they had a lot of camber.
Old 08-03-16, 09:15 AM
jjashaa
jjashaa's Avatar
fender roll and pull in the rear.. 245 tires for stretch and max negative camber the factory arms can do... i've tried it with 19s.. since those are exact specs ran on the Genesis Coupe.
Old 08-03-16, 10:20 AM
kydoshin
kydoshin's Avatar
Yea, I tried searching but haven't seen anyone with the aggressive offset.
Thanks for the info! I was looking to get FIG/Megan camber arms for adjustments (maybe changing out multiple links if necessary) Will the front need any kind of fender mod?
Sorry, still a noob to running aggressive wheels.
Old 08-03-16, 11:19 AM
jjashaa
jjashaa's Avatar
i got the front to tuck nicely with 19x9.5 +22 and 225/40/19 tires
Old 08-03-16, 11:19 PM
NebulaGrey
NebulaGrey's Avatar
Fender roll on all 4 is a must.
Old 08-04-16, 08:16 AM
kydoshin
kydoshin's Avatar
Any good recommendations to where I can get the fenders rolled? I live in OC.
Old 08-04-16, 11:22 AM
Lakersfan
Lakersfan's Avatar
U sure u want to go that aggressive. Im guessing the rears would stixk out past the fender 15-20mm?
Old 08-04-16, 01:06 PM
kydoshin
kydoshin's Avatar
Yea...I want the Face3, which concaves more than Face2
Face3 Left | Face2 Right
Old 08-04-16, 01:16 PM
jjashaa
jjashaa's Avatar
well.. to get you an idea.... this is 20x10.5 +25 with a 245/35/20 tire with the factory arms to max negative as they can go and i'm on air suspension.. also i had my fenders cut.. the shop then unfortunately buckled my rear quarter as they went for a test drive but gladly fixed it while i got a new set so i don't have to deal with this.
Old 08-04-16, 01:39 PM
kydoshin
kydoshin's Avatar
Oh wow, ok. Thanks for the pics! I will change out the factory arms to get more adjustable camber.
Where did you get your fender work done? (if you would recommend them lol)
Old 08-04-16, 01:58 PM
jjashaa
jjashaa's Avatar
I got my car done at Platinum VIP since they were installing the Phantom Cup Kit setup for me... i have my own fender roller so I would have done it myself but they said they would do it for me as a whole package.
Spamboi
08-05-15 07:05 AM
Polkman
IS F (2008-2014)
12
01-03-14 12:57 PM
socal72
08-09-13 09:50 AM
Hexxle
SC- 1st Gen (1992-2000)
24
10-12-12 09:40 AM
dOMEmE
06-22-09 03:06 PM
Quick Reply: Wheel setup advise 9.5 +22F | 10.5 +22R Help
