brake pad thickness question
Old 08-15-16, 07:03 AM
jacktung
jacktung's Avatar
Default brake pad thickness question
I have 2013 GS 350 AWD, and I recently had a service and dealer told me that the front brake pads are needed to replaced. I looked at the service paper and it said brake pad thickness is 4/32 front and 8/32 rear. I drove 37,000 miles on it. Should I replace the front brake pads? what is the min thickness of the brake pad? I am a new to this forum. Please anyone answer to the question. thanks,
Old 08-15-16, 07:24 AM
jj14
jj14's Avatar
4./32 is getting close to the point where you have to replace it (2/32 would be when you "have to " replace it). If the brakes are squeaking though, change it right away, before it causes damage.
Not sure what Lexus recommends - check the manual.
Old 08-15-16, 08:01 AM
bclexus
bclexus's Avatar
Received 2,274 Likes on 1,620 Posts
If [while] the car was in for other dealer servicing and I was told the front pads were at 4/32 I would have had only the front pads replaced...unless you plan to have some other service work done at the dealer sometime in the next ~5,000 miles, or you don't mind the time or hassle of returning to the dealer again. The rear pads at 8/32 will last a rather long time before they need to be replaced...as the front brakes usually wear much faster than the rear brakes.
Old 08-15-16, 08:06 AM
AJLex19
AJLex19's Avatar
Received 1,168 Likes on 863 Posts
Also have a 2013 AWD - recently replaced rear brakes and rotors after 48k miles (car was purchased CPO with 43k miles). Front brakes and rotors still good after 48k miles (not sure how unless they were previously replaced I don't recall from seeing the service history if they were). I believe 5mm-6mm is the general CPO standard for brake wear. New pads are typically are between 11-12mm in thickness so essentially a CPO car should have about 50% of its brake pads remaining to be sold as CPO. At 4mm, personally I would change it. A few helpful threads:
https://www.clublexus.com/forums/is-...rake-pads.html
https://www.clublexus.com/forums/gs-...-4k-miles.html
Old 08-15-16, 12:15 PM
jacktung
jacktung's Avatar
Thanks for the great information ... I guess I should change the front pad soon.. I am thinking about DIY. Is it easy?
Again, thank you very much for you guys feedback~ I love this forum..
Old 08-15-16, 06:22 PM
Dallasguy1
Dallasguy1's Avatar
There's a diy video on YouTube looks pretty simple, getting the ceramic pads Duralast Max cas of the constant squeaking of the fsports.
Old 08-15-16, 11:29 PM
peteharvey
peteharvey's Avatar
Over the past 30 years, I have had two occasions where the very thin pads shattered into small pieces, and the metal calipers ended up grabbing the rotors, such that I had to have the rotors machined.
I would recommend replacing the pads long before it had reached 4/32".
If you are good at DIY, then replacing the pads yourself should be easy.
Old 08-16-16, 08:13 AM
puffdaddy
puffdaddy's Avatar
This is the easiest car I have ever changed! There is a step by step DIY on the forum. The pads are so easy, the wheel removal takes more time.
I have the Duralast (autozone) Ceramic Cmax pads and am VERY happy. Great bite (better than the last ceramic pads I had on my BMW), little to no dust either.
I wouldn't worry about the rears for a while either
Old 08-16-16, 12:16 PM
jacktung
jacktung's Avatar
I read the forum and many people use ceramic pads instead of OEM pads because of dust issue. Is it better to use OEM pads for the rotor?
Old 08-16-16, 01:44 PM
bclexus
bclexus's Avatar
With your non-F GS I would go with factory OEM pads. Some GS 350 owners with F-Sport models use the ceramic pads because the F-Sport OEM pads disperse more dust and also have a tendency to squeal, whereas the non-F brakes and pads don't display those issues.
ydnandy
Suspension and Brakes
30
07-05-12 06:11 PM
Phillip31
50
10-20-11 12:00 PM
poley1
12-25-08 11:55 AM
tmag
09-12-07 11:24 PM
Quick Reply: brake pad thickness question
