Anyone using wheel spacers for AWD GS Fsport?
Old 09-19-16, 03:04 PM
KNIGHTX50
KNIGHTX50's Avatar
Default Anyone using wheel spacers for AWD GS Fsport?
Hello CL,
I've tried searching multiple times and can't really seem to get a clear answer.
I am wondering if anyone is running spacers with stock wheels and if so, what brand/size?
The wheel gap on AWD models are ridiculous!
I plan on lowering the car with RSR Down springs but want to install spacers at the same time.
Thank you for your help.
Old 09-19-16, 04:15 PM
2jS160
2jS160's Avatar
I'm running Ichibi V2 10mm up front & 15mm on the rears w/o any issues of rubbing on OEM springs. Sit's nice and flush with the fenders.
Old 09-20-16, 10:44 AM
KNIGHTX50
KNIGHTX50's Avatar
Hey 2jS160, do you mind posting a picture so I as well as other people with AWD can get an idea?
Old 09-20-16, 12:04 PM
Colorwind
Colorwind's Avatar
I used H&R 15mm spacers on 4 wheels with Tanabe lowered springs. Front is flush but rear is just a bit off. I would definitely use 20mm for rear if I could install it again!
saiko2j (04-01-20)
Old 09-20-16, 12:12 PM
Colorwind
Colorwind's Avatar
BTW, the safest way to install spacers is only to swap all bolts...Few shop in town is willing to do it. I had no choice but let my dealership do it...3.5 hrs in total..a bit costly but gave me some piece of mind.
Old 09-20-16, 12:58 PM
KNIGHTX50
KNIGHTX50's Avatar
Thanks Colorwind!
would you mind posting pictures?
Old 10-03-16, 11:23 AM
jayemko
jayemko's Avatar
Hope this helps with your decision:
2013 F-Sport AWD with stock 19" F-Sport wheels with Ichiba spacers: 15mm Front, 20mm rear.
Actual spacers I ordered on Amazon:
Ichiba WS-5511460A Version II Wheel Spacer (5x114.3 15mm) Link: https://amzn.com/B007ZGCUUU
Ichiba WS-5511460B Version II Wheel Spacer (5x114.3 20mm) Link: https://amzn.com/B007ZGCVIG
Additional notes:
  • Lowered on RS*R Superdown SUS Springs
  • FIGS Rear Upper Links (#2) installed by dealer
  • Rear perfectly aligned, front aligned as close as possible with stock arms
  • Tire size: 235/40/19 all four tires
  • Wheels balanced perfectly, absolutely no vibration between 55-80mph
  • Zero fender pull or roll
  • Zero rubbing up front. Rubbing in back only on speed bumps or driveways (and approach is straight on instead of a slight angle) if I have more than one smaller adult passenger back there, otherwise zero rubbing
  • Installed since May 2015 (about year and a half) and still 100% satisfied
Images:
Rear
Rear
Rear
Rear - Top looking down
Front
andygill27 (01-05-19)
mas3423
05-09-21 10:24 AM
etai9
09-26-15 06:03 PM
lemans777
05-19-14 12:56 PM
JDW379
01-21-14 06:18 PM
myhusky
11-15-08 10:19 PM
Quick Reply: Anyone using wheel spacers for AWD GS Fsport?
