Burnt Copper Calipers, crisis averted, something learned.
Old 06-22-17, 02:06 PM
peasodos
peasodos's Avatar
Received 2,229 Likes on 1,450 Posts
Default Burnt Copper Calipers, crisis averted, something learned.
Painted my Calipers VHT burnt copper and used a 2 part clear coat with a hardener.
The crisis I had is, with the brake pads off I would start the car to turn the wheel to paint both sides of the front caliper. Well in doing so I stepped on the brake. Both rear pistons popped out over the course of turning the car on/off, it was still held on by the rubber dust seal around the piston. I was an idiot and didn't realize you could turn the wheel without starting the car. In any case my neighbor Jerry who's a retired mechanic helped me put the pistons back in. I have a Lexus GS 450h and your supposed to bleed the brakes using techstream(dealer software). Jerry didn't think it was necessary and bleed the brakes the conventional way starting from the rear passenger. Tested and the calipers don't leak and brakes work great. After doing this the non-techstream method, my ABS light, break light came on. Jerry just cleared the fault codes and they never came back. did a few restarts/drive and car does the system check every time, all is good. Now I have fresh brake fluid
The following 2 users liked this post by peasodos:
joedaddy1 (06-22-17), jonathancl (06-22-17)
Old 06-22-17, 02:18 PM
LatinLS430
LatinLS430's Avatar
Calipers looks good!
Glad that your neighbor helped you out!
peasodos (06-22-17)
Old 06-22-17, 06:45 PM
JellyBean
JellyBean's Avatar
Ha! Stupid me. I thought you had *burned* your copper calipers. I said "WTF! Copper calipers????" and jumped into the thread. Looks great though!!!
Old 06-23-17, 08:39 AM
songoku
songoku's Avatar
Glad that it worked out.
Caliper looks great. I have exact same color on mine, too.
Old 06-23-17, 11:43 AM
Wincer94
Wincer94's Avatar
Can you post some side pics of the car from different distance and angle to show the painted calipers? Thanks.
Old 06-23-17, 12:36 PM
dougm213
dougm213's Avatar
Cool
I agree, What a great headline, thus click-bait. The op should work for Yahoo! because at least his/her story was of interest.
ISAVY
Maintenance
11-09-10 05:16 PM
rtk7
11-14-07 04:52 PM
pinoybboy
Suspension and Brakes
05-02-06 03:51 AM
damon
Maintenance
06-03-05 05:06 PM
persian451
09-22-03 04:49 AM
Quick Reply: Burnt Copper Calipers, crisis averted, something learned.
