HUD Retrofit
#76
Hardest part will be cutting the dash. I plan on doing this without removing the dash, by using a template and a really sharp box cutter, removing layer by layer. Looks like the synthetic leather layer, then two layers of plastic. Might have to use a wire saw, I'll update the thread with pics, stay tuned !
#78
#79
Thanks to eddie420 for the template.
Today I cut the nuluxe on the dash for the HUD opening. Very difficult to cut this from the top, like one inch of clearance when you get close to the windshield
I plan on making an opening on the top and using a wire saw, or hack saw from underneath to cut the dash, two layers of plastic to go through.
The dash trim allows me to cut a larger hole to position it perfectly and wide enough to cover up my cut. I plan on using velcro to attach it to the top of the dash
eddie420 (09-14-18)
#80
I'm jelly! I can't wait to get mine started again. Gahh!!! Keep us posted on your progress! I see you have the mod bug also... seats... HUD... steering wheel... headlights... etc... LOL
#81
Started cutting my dash today. Two layers of plastic panels. I used a knife to create a opening. Then I used a wire saw(ribbed metal cable) with pliers and pulling underneath to make the cut. It's not easy and I would not trust myself to put a dremel that close to the windshield. Going to to home depot to get some other tool to finish the cut.
so far 3 sides are cut.
#82
AbetSc (07-23-19)
#87
It wasn't the dremel it was the knife and the wire saw I was using before the dremel. I would end up banging my hand around under there shaving with the knife. The dremel was much easier to control and less labor intensive.
If I were to do it over again I would only use the dremel and wear gloves. I put a wood shingle between the glass and the dash. There are a few cut marks on the shingle so defiantly a must.
The dash is two layers of material, bottom layer is plastic and the top layer is stronger made of some composite.
#88
#90
Found out that you have to remove the dash to screw in the HUD mounting brackets. They screw in from the back side and there is no room to screw it in, but the hud fits in so snug without the brackets it doesn't move. I'm going to add some velcro and foam tape to make it fit extra tight tight.
