Finally got time to bring my car to my friend Tommy for the fog light install. I have Dec 2014 build '15 GS F Sport RWD so I was afraid that I might have the larger windshield washer reservoir to content with.
But to my surprise, my car have the older smaller reservoir. The Morimoto fit perfectly, with room to spare. Took about 2 hrs to do entire install and Tommy didn't even need to remove the front bumper.
I'm listing the parts used below for future reference if anyone want to do this.
If you're in SoCal, I highly recommend Tommy @Musicbox in South El Monte to do the install. He knows exactly what he's doing, very professional job and reasonable fees.
Special thanks to: @PK_Celsior - for the excellent guide. @Nigel-JDMParts - for the harness @eddie420 - for some pointers and detailed diagram
Tommy @ Musicbox - for professional install (626-823-2853)
Parts:
84140-30360 - Headlamp Switch ($133.89)
82998-12870 - Terminal, Repair W/W ($14.34) x 2
LF-Lexus - Morimoto XB LED Fog (Type T-$170.00)
iJDMTOY Garnish Bezel ($39.99)
NigelJDMParts Fog Light Harness ($24.99)
Reason: add pictures and vid
Here's a video of the Morimoto fogs on/off to test beam pattern.
It doesn't really add any noticeable light during driving, but I guess that fogs aren't meant to do that.
Morimoto LED fogs are a bit whiter/brighter than the stock HID.
Can this be done with non f sport OEM stalk using the harness ?and other supporting parts as listed with the exception of morimoto fog light kit
Yup! You can use any other fogs you wish. I only went with the Morimoto because I like the black housing and the heatsink is not as big in the back thus it doesn't interfere with my water reservoir. I've seen other successfully use iJDMToys/NigelJDMParts fog light kits but can't comment if they fit OK. My stalk is actually the non F Sport OEM stalk ordered from parts.lexusofwestkendall.com (part #84140-30360).
Do you have the wiring instructions for the Multi-function stalk (part# 84140-30360). I have the fog lights installed and want to swap out my GS350 F Sport OEM Stalk for the 84140-30360 stalk.
