At My Wit's End - Brake Squeal
Old 02-13-20 | 09:11 AM
  #46
Wilson2000's Avatar
Wilson2000
Brake squealing is most often due to incorrect shims or incorrect shim installation. Of particular concern is the type of grease used on the shims and on the back side of the pads, and the amount of grease used. The wrong grease will not hold in place when the brakes heat up under normal braking. Insufficient grease will not be able to muff the high frequency vibrations that cause the brake squeal.
Old 02-13-20 | 10:41 AM
  #47
JeffKeryk's Avatar
JeffKeryk
I may pull apart the front brakes on my car to slather gobs of grease on the pads and check for which shims are in place.
I believe all work on the car is from the dealer. And yes, I have the low speed squeal which was not there when I bought it under CPO.
Old 02-13-20 | 11:00 AM
  #48
tangierc's Avatar
tangierc
Folks I found this(https://www.clublexus.com/forums/gs-...0001-20-a.html) thread here which has some very valuable information.
To sum up my brake/vehicle experience in case others had the same issue/parts:
  1. Lexus dealer changed my two part rotors to one part rotors in summer of 2018 per a TSB. This service had nothing to do with brake squeal, but a grinding feeling in the brakes and floorboard.
  2. The parts Lexus changed to were 43512-WY010 and 43516-WY-020 (rotors and pads along with some other accompanying parts). This is when the squealing started a lot.
  3. Every time I took it to the Lexus dealer a new problem showed up so I stopped taking it to them.
  4. October 2019 with pervasive squealing, my front rotors and brakes were changed out by my local mechanic. The rotor part (according to mechanic) is 43516-3061 but I can't find that anywhere. The brakes were changed out to Textar brakes.
  5. Within a week the car continued to squeal like crazy cold or warm. Mechanic changed the Textars to OEM Akebonos ASP1118
  6. As of this writing the squeal still persists so I am going to follow the info on the thread I mentioned above for the person(s) who have the same pervasive issue.
  7. Bedding (per a suggestion earlier in this thread) at any point hasn't worked at all.
Old 02-13-20 | 03:11 PM
  #49
Wilson2000's Avatar
Wilson2000
Be sure to use a high-quality brake grease designed for use on the back of the pads and between the shims. Thin, even coats are preferable to "gobs."
Old 03-17-20 | 12:28 AM
  #50
fgs350's Avatar
fgs350
Originally Posted by 3stars1sun
I've had my Powerstop brakes and rotors for almost a year now. I'd say 10k miles of noise free brakes (knock on wood). Part # PWR-K6513. $352 shipped from Summit Racing.
Questions (for a 2015 F Sport GS 350 RWD):
1. Have the Powerstop brakes lived up to what you have expected (noise free, their ability to stop, less dust)?
2. How much would the Powerstop Z23 Evolution Sport Brake Upgrade Kit K6513 cost to install at a certified service shop (ex. brake masters)?
3. Would you recommend Powerstop's newer model (K6513-26)?
Old 03-18-20 | 08:32 AM
  #51
1flossedm3's Avatar
1flossedm3
Do all GS350 F Sports do this?
Old 03-18-20 | 03:39 PM
  #52
signdetres's Avatar
signdetres
No, they do not.
Old 03-19-20 | 04:10 PM
  #53
fugee's Avatar
fugee
It seems that alot of them do. i have an awd fsport and i frequently get the brake squeal.
tangierc
02-13-20 01:17 PM
boostinsc
03-24-19 08:09 PM
flyboyplo
08-27-13 05:58 PM
fud
04-26-08 04:55 PM
Rx900
GX - 1st Gen (2003-2009)
20
07-07-06 12:56 PM
Quick Reply: At My Wit's End - Brake Squeal
