Purchased REVEL Medallion (Tanabe) Axle Back!
Old 05-13-24, 10:30 PM
JauntyBishop
JauntyBishop's Avatar
Default Purchased REVEL Medallion (Tanabe) Axle Back!
Finally pulled the trigger on getting an axle back for my GSF. After going back and forth between multiple setups on youtube, the REVEL's sound and overall look seemed like the optimal choice for what I wanted. I'm going to do the install myself this weekend.
Then by the end of summer I'll pick up the APEXI N1 Resonated Midpipe.
The quality looks excellent!
maddave (05-14-24)
Old 05-14-24, 09:11 AM
Meraki Autoworks
Your #1 Lexus Vendor
Meraki Autoworks's Avatar
Nice!
Let us know if we can get help you out with the Apexi midpipe, we usually have them in stock.
-Josh
__________________
Your #1 Dealer for Aftermarket Performance Products
Orange County, CA
Text/Call: 213 394 2886
JauntyBishop (05-14-24)
Old 05-14-24, 10:03 AM
WaterFish
WaterFish's Avatar
Looks sexy! Sound clip plz!
Old 05-14-24, 09:04 PM
JauntyBishop
Originally Posted by Meraki Autoworks
Nice!
-Josh
Absolutely, I def plan on ordering the midpipe from you guys!
Meraki Autoworks (05-14-24)
Old 05-14-24, 09:05 PM
JauntyBishop
I will get some with with GoPro this weekend after install for sure.
Old 05-14-24, 10:07 PM
designo
designo's Avatar
What's the deal with the name Revel?
Old 05-14-24, 11:23 PM
JauntyBishop
From what I've read, REVEL acquired Tanabe and sells the same exhaust systems and other components under the brand name REVEL.
Revel definition is: "enjoy oneself in a lively and noisy way"
Kinda fitting brand name for an exhaust manufacturer imo.
Old 05-15-24, 03:23 AM
JauntyBishop
Went ahead and got the GSF set up off the ground and did a quick look around underneath.
Might go ahead and swap out TVD and rear diff fluid since I have amsoil 75w90 and WS ATF once I get the front off the ground and leveled. With the axle back out of the way, should make it easier to access.
Really enjoyed having these RaceRamps for the last 5yrs. Have come in handy on multiple vehicles.
If anyone is curious they are Race Ramps RR-56-2 (2 piece, 56" length, 8" lift height, 10" height, 12" width, and 1500lbs rated each. Also 10.8* angle). They clear stock height GSF front bumper without issue.
First time I've really looked underneath, this 16 GSF spent many years in INDIANA prior to my ownership here in FL. So I was expecting more rust/corrosion from salt on the roads. Glad the car was taken care of, so it seems.
Looks like there are 6 exhaust hangers total. 2 per muffler and 1 per midpipe connection. Bought an exhaust hanger removal tool/pliers as well.
Also, I noticed how the axle back piping section is crimped/crushed down from the factory for clearance.
Old 05-15-24, 03:39 AM
JauntyBishop
I've read some threads/posts where people are asking for clarification on rear lifting and jacking points. The red square under the differential is the location as called out within the owners manual.
Also, the blue jackstands are at the pinch welds indicated by arrows/triangles under the rocker cover/side skirts.
My pinch welds were all but mangled and bent to hell from previous owners or shops...
I know a lot of this has been covered on other threads, but if my pictures can get a different view and potentially help someone out in the process, its a win win.
3 hangers per side, 2 above the muffler and 1 at the midpipe connection.
2 exhaust hangers per muffler
NotFSport (05-15-24)
Old 05-15-24, 03:44 AM
JauntyBishop
Also, the midpipe to axle back flanges use donut gaskets. If yours aren't in good shape, this is the oem part number.
1 per side @ $36 each.
The Revel Medallion axle back uses these factory gaskets, not sure on other systems though.
The following 2 users liked this post by JauntyBishop:
NotFSport (05-15-24), Nunz (05-15-24)
Old 05-15-24, 07:06 AM
NotFSport
NotFSport's Avatar
Even though my exhaust is already done, i still appreciate the info and photos you're providing! Love seeing this process play out on your car!
JauntyBishop (05-15-24)
Old 05-16-24, 10:58 AM
IMAGINTHAT
IMAGINTHAT's Avatar
Congrats ! I have the same exhaust and love it. Great look to it, nice deep rumble, minimal drone.
JauntyBishop (05-16-24)
Old 05-16-24, 12:02 PM
JauntyBishop
I went ahead and installed the Revel last night, I couldn't wait any longer. The install was a lot easier than I anticipated. Only need a 14mm ratcheting wrench, wd40 or similar for the hangers, and exhaust hanger removal pliers. The factory donut gaskets were in great shape too. I might replace those later this year when I install new midpipe though. Took less than an hour even with all the road gravel falling off the top of the oem muffler onto your face/body when you drop it down.
Its a easily a one person job if you don't have help, I hung the midpipe/axle back connection at the hanger first, then slid the muffler section into the rear two hangers, bolted it all up and good to go. The fitment is excellent as is the quality of the Revel. Also, a good idea to use either the packing or towel to cover the muffler/exhaust tips while hanging to avoid scratches or damage.
I will get better pics and videos this weekend, for now here are some of the installation photos. Hope it helps anyone doing this job in the future.
Old 05-16-24, 12:07 PM
JauntyBishop
Looks really good! I'll get some more pics of the whole setup from different rear angles. About to take it out and see how it sounds!
Really like this pic of those "Medallion" tips.
The following 4 users liked this post by JauntyBishop:
1wacko (05-16-24), cyfi66 (05-16-24), designo (05-17-24), maddave (05-16-24)
Old 05-16-24, 05:14 PM
lobuxracer
Tech Info Resource
lobuxracer's Avatar
Received 3,957 Likes on 2,396 Posts
Small point, but good to know. WD-40 may cause the rubber hangers to degrade more rapidly than you'd like. I use soapy (Dawn) water in a spray bottle for those mounts. It rinses off and leaves everything a little cleaner too. I've never needed a special tool for the hangers with this.
The following 3 users liked this post by lobuxracer:
1wacko (05-16-24), dcracer (07-14-24), JauntyBishop (05-16-24)
Quick Reply: Purchased REVEL Medallion (Tanabe) Axle Back!
