Lexus debuts 2016 GS F
#287
i've only driven the IS-F (not RC-F) but i found the IS-F to be much LESS satisfying to drive than the IS350 (or even IS250 F-Sport) because the IS-F is so nose heavy. it's immediately noticeable, hence the under steer. but in a straight line the IS-F is obviously quicker.
#288
one reason the ISF understeers because of its puny 225 front tires. Theres a reason why the 2012+ ISF has wider wheels. RCF and GSF have 255 fronts and they have the TVD. It will corner better than the ISF. Yaguchi explicitly said he wanted the GS front to be able to fit larger tires, basically recognizing that was a weakness with the ISF.
#289
edmunds links above somehow got truncated and should be:
http://www.edmunds.com/auto-shows/detroit/2015/
gs-f faq is at:
http://www.edmunds.com/auto-shows/de...-gs-f-faq.html
gs-f faq is at:
#290
m5 still has the best proportions all around.
I wish they would design the GSF from the ground up rather than retrofitting a spindle snout to the original 4GS. The front bumper sticks out too much.
This GSF's headlights and drl actually follow the original 4gs concept, but the concept looks better.
#292
I am disappointed that Yaguchi san has chosen the GS platform to make the sedan counterpart.
I was hoping for a new IS-F since I like the compact and short wheelbase of the RC-F as it will feel a lot more responsive.
#294
In any case, I hope this car is a great drive. The mags and reviewers will no doubt spend lots of time bemoaning the relatively low power, but hopefully they'll comment on the handling and driver feeback and hopefully it'll be good.
#296
Lexus could shorten the front doors of the RC-F, to make room for rear doors, modify the front seats a bit for more leg room in the back and an RC-F sedan would have been the ultimate solution I was hoping for.
#297
The 4 door RC F or the IS F many have been wanting / waiting for is the GS F. Maybe facelift IS will get new V6 turbo and come closer to RC F straight line performance with lower weight, but I don't expect any IS F in for this generation. Or V6 Turbo + Hybrid at facelift?
#298
#299
Super Moderator
Not sure if that is the reason. Looks like Lexus did not want RC-F coupe to directly compete against a sedan. Lexus could have easily done what BMW with the E92/E90 M3. When the E90 sedan could not work for the M3, BMW essentially made an E90 M3 sedan out of the E92 M3.
#300
