Wet season tire: Toyo Proxes 4 +
I'd like to get a tire that is top notch for wet weather around here (Seattle). Any recommendations? the local les schwab recommended the toyo proxes 4 + ? should I look at other tires? I see consumer reports recommends Michelin pilot sport a/s 3+ and Pirelli p zero all season plus as their top two choices.
also the quote for the toyo buy and install is 1600, is that good?
*I know there is another tire thread but decided to create a new one to focus more on tire models.
I'm not sure why your looking at an ALL SEASON tire? The Proxes 4 Plus is an All Season tire that comes in one size only 235/35/19. Too small for your application.
http://www.tirerack.com/tires/tires....=Proxes+4+Plus
The Michelin PSS currently on your GSF is a Max Performance tire that also works well in the wet. It is however, unsuitable for freezing conditions.
Lou
Lou
Lou
Lou
I did lookup the size and it's the right tire size, matches the lexus.com site - http://www.lexus.com/models/GSF
sounds like I might as well just use the stock tires as I can't get something considerably better for wet?
^^^^GSF tires sizes are 255/35/19 front and 275/35/19 rear. The Tire Rack page only lists one size, 235/35/19.
And Yes, all Mac Performance tires, that I am aware of, are good in the wet.
You may want to read this:
http://www.caranddriver.com/comparis...omparison-test
And download the test results.
Lou
Lou
