Who Said We Can't Run 305/30/20 PSS
Lou
16GSF00336 (12-19-16)
I'm experiencing positive results as well.
Guess I did misunderstand your post. On the ISF the stock stagger you mentioned was 30mm the (225/255). I have increased mine to 40mm (255/295). On the ISF the front to rear stock ODs are exactly the same. With my change to wider, lower profile rubber, I have maintained the stock OD. Maybe I am living in a dream world, but things seem to have improved (a lot) for me.
Lou
Lou
VNN326 (12-19-16)
16GSF00336 (01-09-17)
13FSPORT/VINHsanity:
Wheels: ADVANS Premiums GT Front - 20x9+38 / Rear - 20x11+39
Tires: Front - Michelin PSS (265/30/20) / Rear - Michelin PSS (305/30/20)
Lug Nuts: Volks
GS-F Alignment Specs:
I've set both "Rear" Camber at Negative 3-Degrees...That's ONLY 1-Degree from OEM Spec...
IMPORTANT: Review tread with the notes that I've listed and you'll be fine. NO rubbing what's so ever!!!
The only compliant: The RSR Front Springs are to SOFT...Nothing like Coilovers can relief...
WARNING!!!! If you run the same set...DON'T....DON'T....Run more than Negative 3-Degrees Camber...The Tires "WILL" rub the inner protective fender liner and shock cover...
PS: I hope this helps with your build and looking forward to seeing the fruits of your labors!!!
PPS: Just completed a 600 miles road trip with this set up on Texas twistys back roads so I'm LOVING this set up with the wide tires...
Lug Nuts: Volks
Stormryu (01-25-17)
Not really when your comparing to OEM specs...I'm willing to live with 1-degree off from manufacture spec for better traction or 2 inches more of tire from stock (4 Inches total in the rear)
PS: The RC-F has wider rear fenders than the GS-F from factory... That's why you guys may have those nice concave and fat lip rims...
There are always traded offs when we modify our cars...its just what are you willing to give up to gain...
By the way, Love your Build...
ISFPOWER (01-09-17)
Thank you, loving your car as well. #305crew
Tech Info Resource
-3 degrees will burn through tires much faster than stock. Usually toe kills tires, but anything over 2.5 degrees on modern tires means significant edge wear (doesn't matter if it's positive or negative, it's going to wear on the edge fast).
