Bird chirp sound
![Thumbs up](https://www.clublexus.com/forums/images/icons/icon14.gif)
Small victory tonight. I found and at least temporarily fixed the squeak in the door. It is caused by the seal at the leading edge of the door (see pic with the blue plastic tool) rubbing against another plastic shield installed at the rear of the front fender. Mine was rubbing dead in the middle. I cleaned it and applied 3M dry type silicone (the same stuff the dealers use) and the noise is gone. To do a completely effective fix, one would likely need to remove the door to get access to the piece mounted at the rear of the fender. Anyway, pics are here to show where the problem exists. If you spray the silicone directly on the seal with the door closed, you'll solve 80% of the issue. I opened the door and sprayed the other piece as well. It is quiet as a church mouse now.
