Need help with wheel offset
Ok so Im going to order a 3 pc set of DPE wheels and I dont know what is the best offset I should get? I think Im going to run 265-30-20 on the front and 285-30-20 on the rear. Also im not looking to roll the fenders or quarters and also going with coilover
Fronts
20X9 et38
20X9.5 et 28?
20X10 et 30
Im def going with 20X11 et 40 for the rear
Fronts
20X9 et38
20X9.5 et 28?
20X10 et 30
Fronts:
20X9 et38: Mild
20X9.5 et 28: Aggressive
20X10 et 30: "Innovator"
Just like someone "Pioneered" 305/30/20 on the Rears...![Wink](https://www.clublexus.com/forums/images/smilies/wink.gif)
20X9 et38: Mild
Fronts
20X9 et38
20X9.5 et 28?
20X10 et 30
Fronts
20X9 et38
20X9.5 et 28?
20X10 et 30
13FSPORT (03-31-17)
You may find this thread interesting:
https://www.clublexus.com/forums/gs-...30-20-pss.html
Wheel specs are on P. 2.
Lou
Lou
13FSPORT (03-31-17)
![Talking](https://www.clublexus.com/forums/images/icons/icon10.gif)
That's the same tread I PM you back...LOL...![Stick Out Tongue](https://www.clublexus.com/forums/images/smilies/tongue.gif)
Lou
Lou
I was actually just test fitting my old 19" Forgestar wheels last weekend to check the fitment.
On the front my 19x10" +29 was sitting just outside the fender line and with the 255/40-19 tires on them it would have been pretty close to fitting. Maybe a little rub without a front fender roll.
On the rear my 19x11" +41 were sitting inside the fender line a bit. I would probably add a 5mm spacer on the rear and run a 295/35-19. After looking at inside and outside clearance I think you could put a 12" wide rear wheel on our cars with a bit of tire stretch. Hope this info helps.
Great...Feedback!
