that honestly looks perfect with the 20mm spacers.
I just did the 15mm to be on the safer side.
tomorrow im going to be doing to work swapping out the studs hopefully it wont be a total pain in the ***
Eibach claims 15mm spacers will not work without replacing the oem lug bolts with longer ones. Hopefully you weren't driving with the 15mm??
Need some help. Looking to get wheel spacers for my stock 2016 GSF. Most people on this forum and others like the look of getting their tires flush with the fenders. I personally like the tires sticking out just a little bit more than the fenders.
After researching quite abit I found that Bullets Garage on YouTube and a few others prefer H&R spacers. However Bullets Garage showed that 15mm in the rear sit flush with fenders and 20mm for the front.
H&R DRS Wheel Spacers - 15mm / 5x114.3 / 12x1.5 / Bore: 60.1 The above specs are what Bullets Garage posted he used.
I want to order 25mm for front and 20mm for the rear. My question is do I look for
H&R DRS Wheel Spacers - 20mm / 5x114.3 / 12x1.5 / Bore: 60.1 & H&R DRS Wheel Spacers - 25mm / 5x114.3 / 12x1.5 / Bore: 60.1? Would these be a plug and play type of thing or would I need to get different lugs/nuts/bolts?!?
Contact us for pricing, we offer international shipping to Bahrain!
-Josh
Ok amazing! Dont know what gave you the impression I'm in Bahrain cause I'm not lol before we get to pricing can you share which type you recommend. Was told to only use drs and not drm...which brands do you guys sell?
No issues with install, but... if your car is lowered, you will slightly rub in the front when you turn full.
You're not the only one that's said that about H&R! Thanks for your input btw...my car is completely stock so hopefully wont have any issues with the rubbing..... I looked on their site though and they don't have 25mm... could you share what you ordered from them please? I was told by someone else yesterday to only order and install the DRS and not the other ones that come with the pre installed bolts.... I'd highly appreciate it if you could share which ones you ordered so I can finally get around to ordering some for mine!
Funny enough, the Bullets Garage YouTube is run by the thread originator, gsfdream
Rafael ( Bullets Garage ) is awesome. I'm a hard core follower of his channel!
Here's my car with 25 front and 20 rear. Some say it's too much, but I love it. Especially if you get the camber kit installed and adjust your cambers accordingly to give you that nice fat planted look!
hey since your front tires are turned in can't really tell how much the 25mm stick out in the front could you please share which one's you ordered? I can't seem to find the 25mm for the front from H&R
