Owned (2x) IS Fs - Thinking About GS F
Old 01-17-18, 10:17 AM
gsfdream
gsfdream's Avatar
The fluid level in the gearbox. On the IS F, the gearbox is very sensitive to low fluid levels. Even a few ounces low caused flaring under certain conditions. The GS F gearbox has not had any flare issues I've noticed, but the clutch engagement has been noticeably clunky on the GS F compared to the IS F. Both have the AA80E gearbox, so it pretty much has to be the TCU programming or the fluid level might be a little low. No way to be sure without setting the fluid level (you can't actually "check" it, you can only adjust it from too much to just right).
is there a tranny dip stick or fill hole or anything to measure if fluid is low or not?
Old 01-17-18, 03:46 PM
lobuxracer
Tech Info Resource
lobuxracer's Avatar
Received 4,076 Likes on 2,470 Posts
There is no way to determine if the level is low without going through the entire level setting procedure.
aginnt
GS F (2016-present)
15
07-12-17 02:21 PM
u7mg0
02-06-16 06:56 AM
EthanV
03-05-13 07:37 PM
passnu2
11-13-10 05:31 PM
LexFather
06-01-06 08:25 PM
Quick Reply: Owned (2x) IS Fs - Thinking About GS F
