20mm spacers + RSR springs + stock wheels
So I've got the stuff ready to be installed. I'm set on the 20mm H&R's on stock wheels.
I'm hesitant on the springs though. What are your thoughts? Any future issues with my adaptive suspension?
I'd love some input from those more experienced members here please
Thanks
Thanks
I've heard that you should go with coil overs as other users with springs noticed their shock had to be replaced soon after. I have Swift springs that haven't been installed yet and maybe deciding to go coil overs. KW makes a nice one. Single adjust.
Your #1 Lexus Vendor
we have swift springs being released.. Ride will be x100 better than the RSR!
-Josh
-Josh
__________________
Your #1 Dealer for Aftermarket Performance Products
Orange County, CA
Text/Call: 213 394 2886
Orange County, CA
Yeah, only 8 weeks to get them. I looked at FedEx and it still haven't been released from sender. This is one of the worst buying experience. Never buy if it's in back order for more than 4 weeks.
If you care about performance, get coil overs as replacing just the springs will cause premature wear of the shock absorber AND handling issues. If you only care about looks and don’t mind blowing out shocks prematurely and taking a hit on track performance, then replace just the springs.
Did you verify with Swift if they're an authorized seller?
-Josh
__________________
Orange County, CA
Orange County, CA
Lexus Enthusiasts
I've run lowering springs on car from Lexus, Infiniti, BMW and Mercedes and as long as you get a reputable brand and not eBay you are good.
For the more reputable spring brands, they develop their springs in conjunction with OEM Shocks. They dyno the OEM dampers and develop springs to work in line with the OEM damper travel and compression, so I wouldn't be too concerned. Even with adaptive suspension setups like how Audi uses magnetic fluid to increase stiffness of the dampers, the springs themselves are generally just softer rates than spring upgrades. Plus even with adaptive suspension the springs are still linear springs that don't adjust, its just the dampers adjusting their internal piston or the fluid. You could argue that it would prematurely wear out the OEM Dampers since a harder spring would decrease the amount of suspension travel, but honestly its not by a huge degree.
Very nice.
Glad you like the parts!
-Josh
-Josh
__________________
Orange County, CA
Orange County, CA
designo (04-30-18)
The following 2 users liked this post by SilvaIS350:
designo (04-30-18),
Meraki Autoworks (04-30-18)
