Light Weight Battery options
If going the Lithium route which battery would you recommend?
If going AGM route, which battery is the most light weight?
Thanks
Thanks
Check in the RCF build threads. I know several of those guys were using Lithium.
https://www.clublexus.com/forums/bui...-build-32.html
I did some Digging and the GSF has an 180 amp alternator, so it seems that not many of these Lithium battery will have enough juice to match the requirements.
What are thoughts on Lithium battery and matching it with the factory Alternator?
Mike234588
09-11-16 11:27 PM
masboy
03-04-12 06:37 AM
