Heated Steering Wheel
Old 10-13-18, 06:08 PM
Ay-nako
Stop the Copy!
Ay-nako's Avatar
I’d have to assume you’d need a new harness as well, not sure if you remove the control panel if there is already a plug ready for that fourth button.
Old 10-14-18, 09:35 AM
texaslexii
texaslexii's Avatar
I hope thats not the case and that the button above where the steering wheel heat is at is shared with the same harness.
Old 10-14-18, 12:06 PM
lobuxracer
Tech Info Resource
lobuxracer's Avatar
Received 4,076 Likes on 2,470 Posts
There are six different part numbers for the wire harness in the dash. Hard to say what is or is not included without opening it up and looking.
Old 10-14-18, 12:10 PM
texaslexii
texaslexii's Avatar
Well if that is the case then I'm shelving this mod, dont want to replace dash harnesses.
Old 10-14-18, 08:36 PM
lobuxracer
Tech Info Resource
lobuxracer's Avatar
Happy news. The wiring is present in the wife's '16 GS F. I just validated it and in the process saw what a kluge the illuminated door sills are. Ugly harness hack on the install.
Old 10-15-18, 06:30 AM
texaslexii
texaslexii's Avatar
Yay, thanks buddy, appreciate you looking. Guess the mod is back on the plate. First mod I did was install the illum., sills. Wasn't bad, used the included wire taps for ground/power.
Old 10-16-18, 08:17 AM
texaslexii
texaslexii's Avatar
Originally Posted by eddie420
I can't really tell you anything about the GSF since I have a GS350 with cold weather package and it came with the heated steering wheel... but I did tear apart the steering wheel and want to share some pictures so it can give you an idea of what is in it.
This is how my steering wheel looked from the factory
Can you post the part number for the control panel that has the heated steering wheel button? Don't know if the button is available by itself or you have to replace the whole assembly that has the ASC/TCM/Auto high buttons.
Old 10-16-18, 08:38 AM
texaslexii
texaslexii's Avatar
84308-53020. Runs about $250 all by itself. $550 if you buy it with the sensor. Not sure if you need the sensor matched to the clockspring.
Can you check for me if that part number is the correct one? I am seeing these options
I do have pre-collision, so I assumed it was 8430853040 CABLE SUB-ASSY, SPIRAL 84306 URL10..ARL PRE-COLLISION SYSTEM-WITH(GSP)&STEERING WHEEL-F (W/HEATER) even though it states its for cars built after 9/2017, and does it really matter? Thought they were all identical.
I need to make sure I get the correct one because returns are not accepted on electrical parts.
Appreciate the help!
Old 10-17-18, 06:26 AM
texaslexii
texaslexii's Avatar
And here's the control module/panel, cheapest price found 135
https://www.discountpartsmonster.com...y-8401030n20c0
https://parts.lexusofwestkendall.com...30n20c0?c=az0x
Old 02-01-19, 08:33 PM
CobraGSF
CobraGSF's Avatar
reviving this old thread.. has anyone successfully done this? its really cold now and i wish i had this feature lol.. i saw on instagram Elvin is playing around with retrofitting the heated steering capability on his custom CF wheels.. but in order to retrofit i'd need to have an extra port on my airbag or something not sure..
Old 02-02-19, 09:03 AM
texaslexii
texaslexii's Avatar
No sir, that is incorrect. I asked him about retrofitting heated leather and cant be done, another vendor couldnt do it either.
Old 04-07-19, 10:19 AM
Artemis
Artemis's Avatar
For Polish market all mentioned options were available
Old 04-09-19, 04:37 PM
Ay-nako
Stop the Copy!
Ay-nako's Avatar
Too bad! I miss having a heated steering wheel!
Old 05-10-20, 12:54 PM
tlove8
tlove8's Avatar
Hi eddie,
Were you able to get the heated pads installed into the carbon fiber wheel? I am considering doing the same, i have the new wheel but scared about opening my old wheel and pulling the pads out. Any issues with that process?
Thanks!
T
Old 05-16-20, 08:36 AM
g356gear
g356gear's Avatar
Originally Posted by obadea
Does anyone have a heated steering wheel on their GS-F? Does not seem to be available.
My 2016 Canadian car has heated/cooled seats and the heated steering wheel.....
unioncorps
11-09-23 08:59 PM
GISguy
09-14-16 02:43 PM
MD TEACH GS300
01-25-16 09:51 AM
mcfancy
RX - 3rd Gen (2010-2015)
11-09-12 12:22 PM
Quick Reply: Heated Steering Wheel
