R1 concept brakes
The following 2 users liked this post by naquin123:
designo (06-27-22),
R1Concepts (11-09-18)
LRCSALES (11-12-18)
finny76 (11-09-18)
naquin123 (11-09-18)
Lou
^^^^It really depends on what you want. Track, Dual Purpose, Street Pads - all have different characteristics. Performance vs noise vs dust. See these threads:
https://www.clublexus.com/forums/lc-...ke-issues.html
https://www.clublexus.com/forums/lc-...ifference.html
Lou
Lou
NinjaNap (06-28-22)
^^^^OK, not going to argue! There are pads and there are pads. I have no frapping idea what pads you are talking about. Again, IMHO, the stock Brembos are very powerful and with the proper pads can be used on the track and the street. IMHO, there are many things that would benefit the GSF far more than replacing the already powerful brakes with another set of powerful brakes.
I'm thrilled you're happy with your pretty green brakes, but with equivalent pads your GSF will not "stop" any better than stock. You have bigger brakes than the track oriented Corvette ZR1. The ZR1 comes with brakes with the same specs as the stockers on the GSF, except for the ceramic rotors, which you do not have.
Lou
Lou
Edit: Just saw you said those were 8 piston calipers. I'd still say that there are diminished returns.
Lou
Lou
The only true way to test brake performance is to take your car on a track and run several laps with hard braking.
changing 6 piston calipers to another 6 piston calipers seems like a side grade to me. Brembos are tried and true.
but other than that they do look pretty cool though
^^^^I agree, that's why I put the word stop in quotation marks. BTW, the OPs front brakes are 8 piston in front and 6 in back.
And, why did you edit my post
Lou
Lou
You all have great opions I didn’t change them because I didn’t like the brembos I had the R1s on my F sport for less than 1k miles so I decided to put them on my GSF . But I was going to keep the Brembs but the wheels you see on my car wouldn’t clear the brembos . I like both bbk
I got the Tom's performance brakes and it works well on the track. Not sure if there is more braking power, but I feel like even after 7 laps the brake power doen't fade, where I think the stock brakes did a little.
