Canadian Spec GS-F
When GSF listings do come up in Canada they go pretty quick.
Here are 2 listings on Facebook from the west coast (not sure how to link them properly - just add facebook.com before these two links):
$43,500CAD ($32k) - 2016 w/ 113,000 miles:
/marketplace/item/1154438525221435/
$79,000CAD ($58k) - 2016 w/ 17,000 miles:
/marketplace/item/825987671984981/
On a positive note, though, the process of buying a GSF in Canada and importing it into the US really isn't bad. I did it myself last summer and, as long as you are organized, it's probably less than a month from purchase to the GSF being delivered. My Canadian GSF actually has Canadian and US plates/markings, even an EPA sticker, so it's way less complicated than other imports.
With the disclaimer that I am NOT an expert in these things, I believe it is possible for the GSF because there is a case to be made that it is sufficiently similar to the GSF that was sold in the US. I am not sure about Euro/Aussie/Middle Eastern spec GSFs, but the Canadian spec ones actually have all of the US markings (emissions, safety, etc) on them when built, so the process is exceedingly easy for Canadian ones. This might og out the window for GSFs with the steering wheel on the opposite side, though.
Canada to US is like going a state over (sometimes)... basically DRL's are mandatory here, and sensors to tell you that your wiper fluid is low. I think backup cameras are mandatory as well... we don't typically get too many "stripper" models of cars like you would in the states'
I recall seeing in another thread that almost no GSFs were sent to Canada, with the total maybe being under 100. I also believe that the majority of them were the 2016 year, which means the 2017-2020 could be single digits per model year, which will make it nearly impossible to find for sale, let alone snag before someone else gets it.
https://www.clublexus.com/forums/gs-...tatistics.html
2019 - 170 (7)
2018 - 166 (2)
2017 - 341 (12)
2016 - 1,387 (38)
2018 - 166 (2)
2017 - 341 (12)
2016 - 1,387 (38)
ICBC Registered GSFs:
2016 - 11
2017 - 2
2018 - 0
2019 - 1
2020 - 2
2016 - 11
2017 - 2
2018 - 0
2019 - 1
2020 - 2
GSFhopeful (03-07-23)
entr0pic (03-19-23)
I went to look at it today. Looks pretty amazing. near imperceptible darker spots on the seat side bolsters, which makes sense as the seats are red. the car appears to have been very well taken care of and its appearance matches the low mileage. Will likely test drive on Monday. Unsure if to cancel my GX order for this given the higher versatility of the GX for my needs.
You cannot. You can change everything from kph to mph, but the climate control settings are set differently, so the car remains in C. It's kind of fun to have a car in C so you can confuse people when they see the temp set to something like 17.5.
Most likely it's in the climate amplifier. I was looking to get the climate amplifier from a wrecked Canadian GS-F to get the 3 climate zone.
Tech Info Resource
peasodos
06-26-19 11:40 PM
