Anyone use a Quickjack for their GS F?
So........ My Xmas gift to my self, other than the GS F was a Quickjack 5000EXT (this is the one with the longer frame). I have a few cars that I will be using it on and I took some measurement at the jack points and it should work with the GS F. Well.... It looks like with the side skirts and some aero in the middle it will be hard to get it to jack. I'm probably going to make something, weld, machine, etc., so that I can have better access to the jack points of the car. Anyone else do something like this, or even have the Quickjack? For the price it's not bad.... It's no two post lift, but for what it is, it's okay enough. Would like to know how others get their car in the air. I'm sick of using a jack and stands. I like this thing cause it seems safer. Although, it's 80 some pounds each side to move around...
Curious to see where the clearance challenges are. I've been thinking about picking up a quickjack as well, but am concerned with clearance on my Novel side skirts. Are you running into height/clearance problems getting it under the car? Or is the challenge more reaching the OEM seams or lift points? If its the seams, try this:
https://zl1addons.com/collections/ca...0-15-lift-pads
I installed them on mine, permanently mounted and it makes jacking up much easier. It gives you easier access from under the car and you stop bending the crappy oem seams. Maybe the quickjack can reach this easier since it will drop down about an inch below stock lift points?
Thanks for the link, yeah, I'm having an issue with the OEM lift points. I have a few ideas and if they work out, I'll make sure to share on the forum. I will have to check out the lift pads too, I feel like with those the Quickjack should fit okay and than I'll be able to use it easier.
I think with these new lift pads the quick jack 5000 ext should work. When I get around to it... I'll make a video and post it up. Might not be for a bit, since the weather sux.
How did the lift pads work out? I bought the 5000 for my IS, but I'm experiencing the same problem
Sorry for the late reply. Lift pads are working well. I did have to shim them out with some flat stock. I don't think the standard QJ would have worked with my GSF. Car is longer than it looks at the lift points.
Thanks you to everyone for sharing your solutions. I actually had to send the 5000slx back and will be purchasing a 5000ext instead. I measured for clearance and it looks like quick jack's pinch weld blocks should (barely) fit in the space around the jack points so I should be good!
Curated Content Editor
04-03-19 04:54 AM
