"dealer only" programmable personalized settings
Does anyone have any non-standard options programmed by a dealer? I went with the no delay when pressing the trunk key on the FOB and opted for the steering wheel to stay in place when ignition is turned off. I felt like this would be a lot of long-term wear and tear on the motor, and I'm not that fat (yet) where I need the steering wheel moved up to allow my gut to slide into the seat ![Smilie](https://www.clublexus.com/forums/images/smilies/smile.gif)
Just started this thread to see what options others chose and why...
Most common requested Techstream setting change has to be the "Remote Window Roll down".
Standard default was On before 2010 keyless fobs debuted, RWR is now defaulted Off.
Press and hold the fob unlock button to begin rolling down/opening all windows/sunroof to
vent a hot car. Stop pressing to partially open them, continue to hold to open fully. Apparently
folks were inadvertently pressing the button and discovering open windows...during a rainstorm...
so you now have to go in (or get and subscribe to Carista) to enable this. The related feature
setting is "Key in the Driver's Door Lock Cylinder Roll up/Close". Great when leaving the car
and discover an open window/sunroof...key in the door, CCW twist and close them all. A bit
awkward on models with the cylinder under a cover but terrific on those built with exposed keyholes.
Tech Info Resource
There are a whole lot of options in Techstream. I've poked at all of them because I have a legal subscription, but there are some things you have to do through menus in the car (like turning off the pre-collision nightmare), and others only available in Techstream. I did this over a year ago, so I really don't remember all the details, but I can take a peek at it and do some screenshots if there is interest.
I got a credit card key just to avoid this problem. Walked into the garage too many times to rolled down windows and open sunroof. I really almost never used this feature and since the auto roll up is not available in North America, it seemed pretty worthless to me.
Please do
From the list of customizations on Carista, I configured the car to allow me to open windows/roof from the keyfob, that’s about all I’ve done. There’s certainly a lot of small changes you can make, would be interested in what else we can change.
Tech Info Resource
So far all the mentioned ones are user modified here as well. There are fewer and fewer LPS settings requiring Techstream these days.
rx350drivr
RX - 3rd Gen (2010-2015)
64
06-05-23 07:18 AM
