Electronic Parking Brake Malfunction
#61
Tech Info Resource
There is no initialization procedure in TIS for a 2021 IS350. Not sure where your problem is, but this initialization isn't shown at all for your model and year.
#62
Most codes like this need to be cleared. The NX uses a different procedure. You need to short the pins, then pull the switch to the lock (set) position 5 times.
Within 5 seconds after turning the engine switch on (IG), pull the electric parking brake switch (integration control and panel assembly) to the lock side 5 times.
#63
Can you please help me with the paperclip instructions? I'm in dire need of my car and don't know what happened.
#65
THIS is one of the most lit posts I've seen in a long time. Something to learn about so many procedure and components I never even knew existed.
Due to possible issues involved with a mere battery change I have decided the best way to change the battery myself (if I have to) is
1. Block the wheels.
2. RELEASE THE PARKING BRAKES
3. Connect this thing if there's any chance the battery is holding memory settings...
4. Only after doing all that, cross your fingers, perhaps say a quick prayer or two and change the battery.
5. Better yet have the dealer do it probably...
#66
Tech Info Resource
That's way overkill. I've changed the battery in the GS F in my garage with zero issues more than once. Just be prudent and don't make/break connection by fumbling around with the battery connections.
#67
M
#68
I can't believe lexus went this route with this silly parking break system so much for reliability?? Note disconecting the 2 plugs in the ecu in the trunk and reconnecting them basically does the same as the memory reset procedure with pin 4 and 13 shorted.
. So has anyone replaced the brown box ecu inside the trunk on the driver side to see if this cures this?
New part is 749 , many on eBay for 50 to 100 bucks I've ordered one to see if this cures it.
After the memory reset I can engage and disengage the E brake about 5 to 7 times before this error returns. I can't see this being wiring, mechanucal actuator or the relay or switch. Which leaves the ecu in question 🤔.
#70
Tech Info Resource
OK. So you do this thing not in the manual, and it doesn't happen again for 5 to 7 times, but if you do what's in the manual, it NEVER happens again. Nice fix!
#71
no both methods only clear it for 5 to 7 cycles of normal use then it errors again. I'm gonna throw an EPB ECU see if that helps any. I have not scanned any codes when its in error as I don't own anything to read these EPB codes. Just curious if anyone here has replaced the EPB ECU
#72
Tech Info Resource
#73
2015 gs350. I was missing the proper steps in the procedure and I think I was not completing it correctly. Did it exactly as its explained and seems ok for now. I'll test it and see if it comes back.
#74
I've tried this both ways where I remove the wire then release the E brake switch in the end or keep the wire in the DLC and release the E brake both clear the error in the dashboard but it returns right after 1 or 2 uses. One time it took 3 miles of driving before it came up, really disappointed with this lame idea of lexus introducing this crappy ebrake crap when the foot pedal and cable has worked fine for the last 60 years. If its working reliably why change it toyota????
#75
Tech Info Resource
