Headlight lens cracked
Has anyone dealt with a headlight lens cracking? both my headlights has hairline cracks on the top area about 6 inches long. i don't see any impact on the lights which could have caused this damage so i'm not sure if this is a defect in part or not. Plan to stop by dealership when i have some free time. Also does anyone know if the lens off a regular headlight non tri beam would fit the tri beam headlight? just trying to figure out some alternative options in case this isn't warranty.
My buddy with a rcf had similar cracking like yours but on the inside lower lense which was covered by warranty.
Tech Info Resource
53k miles, production date 11/2015, and no cracks. Is your car normally parked outside?
Do you use chemicals like acetone to clean them?
To the OP:
I had the exactly same issue at 25.000 mileage (‘18 GSF). I was told that it’s a material fault and was replaced with brand new ones through warranty. I had also a small crack in my DRL leds, but the new headlight units come with new led DRLs, so I have no issue now. Without warranty the bill would have been $5,3k
![EEK!](https://www.clublexus.com/forums/images/smilies/eek1.gif)
Funny how i have 24,500 miles on mine and this happened. so i dropped it off at the dealership and a day later they contact me to give me an update. they said they can't warranty the headlights because they think someone sat on my hood which caused the lights to crack. there's no damage signs on the hood to prove this and they have no way of proving this. so adviser said he will speak to foreman and manager again. calls me back hours later and tells me they cant warranty it because its not a lexus manufactured part. also said they have never seen this before on any other gs models and that's why they cant fix it under warranty. I'm about to go up to dealership to pick up and the car and talk to a manager if hes still there about this and file a complaint to lexus corp.
![](https://cimg8.ibsrv.net/gimg/www.clublexus.com-vbulletin/1500x2000/2245bfff_f7af_46cb_8ab7_d86dbde3bef7_fce3ab0d28ba71bdc8f80e46430f5fe934a76ccf.jpeg)
![](https://cimg9.ibsrv.net/gimg/www.clublexus.com-vbulletin/540x720/27642314_626d_4cdb_ad00_5f48882c0c22_ec118adea07e42464a8299dea5bd90e153a687b1.jpeg)
I had these cracks, on the same position on both of my headlights. It’s definitely factory defective, Lexus should just file a complaint to the it’s headlight supplier and change it under warranty. I don’t understand why US dealerships are so against it’s consumers, here in Eastern-EU the process was simple and fair, but took a bit long though (almost 3 months passed between my complaint and the install, they blamed the shipping).
*UPDATE*
Lexus called me after i filed a complaint about this whole situation. The case manager that's handling my case is off today, so someone else called me to give me an update. she said there's notes written on this case stating lexus will not cover this under warranty. i asked for their reasoning and they said i have to wait until monday to get an explanation from the person handling this case.
