Best brakes for GSF
Hi All,
I own a 2016 GSF and my brake pads and rotors are overdue. I was wondering what you guys are paying to get your GSF's brakes changed? I live in East Bay, CA, and I'm debating if I should take it into nearby Lexus dealership or any auto shop recommendations!
Thanks in advance.
Thanks in advance.
DanfromTX (10-06-23)
Hi All,
Thanks in advance.
Thanks in advance.
-Josh
__________________
Your #1 Dealer for Aftermarket Performance Products
Orange County, CA
Text/Call: 213 394 2886
Orange County, CA
What are you guys doing for the wear sensors? Purchased a set from rock auto which are flashing the brake wear indicator worse than my worn OEM's. Is there a re-set procedure that I missed?
No reset. It's just a wire, so if you still have a wear indicator you don't have continuity on one or more of the sensors. I didn't like the quality of the Rock sensors, so I rewired mine with the OEM connectors. The Rock Auto connectors are pretty sketchy IMHO.
Brake pads are subjective, it really depends on what you are looking for.
There are a lot of brands out there that are cheaper but most GSF guys complain about the dust and the squeak
Crowd favorite for street driving is the Project Mu type NS.
I went with the type PS on my GSF for a little more performance but yet no sound and very little dust.
Tom's racing performer pads are also a good option.
If you don't want a noisy and dusty brake pad set up, make sure you don't get race pads. Unless of course you don't mind it and do track your car.
I also don't recommend resurfacing rotors, there are cheaper yet good enough aftermarket rotors like Stoptech/Centric that is 1/4 the price of the OEM.
-Pressure wash the brake dust out through the wheels
-You'll probably need to wear the brakes in evenly maybe once every 700 miles. If the problem persists, you can take the brakes apart, grab a wire brush, some brake cleaner and get to work removing the excess dust.
Project Mu Type NS. Much better than the OEM Brembos in terms of dust and noise. With 4400lbs of heft minus the driver it seems the bite isn’t much different. They get much better as they warm up.
If anybody would like a great read on brakes click here :
https://www.clublexus.com/forums/the...then-some.html
Why? Jurid is OEM according to the stamps on the backing plates. I run different pads from a wide range of manufacturers on different applications, and have run Ferodo pads on my race bikes. However, there isn't any magic to brake pads as long as they suit your application.
Basically speaking - whether you are a real spirited driver or barely warm up your brakes at all during your regular drive these European brake pads are much better for the overall health of your rotors which results in overall better braking performance without needing to worry about occasionally "bedding" your pad into the rotor to help it wear evenly and restore full braking performance.
Because these dusty european brake pads "sacrifice" the pad and uses these special abrasives to effectively sand off deposits from your rotors everytime you brake. It sort ofmassages the rotors and gently conditions them unlike the pads you will find on many casual commuter cars with those basic dustless pads. The japanese hate brake dust with a passion and use very expensive friction modifiers to prevent it so unless you do a light bedding procedure you run the risk of uneven deposits and reduced braking performance.
