The Super Sport summer tires are gone now and it's time for new 20 inch Rims/Tires.
Currently I have the USB 17 GSF with the Novel Lip Kit.
I've searched all over the internet but have yet to see a blue GSF with bronze Barrel and a CT Silver face.
I really like work's 2p and 3p style, also the reliability is great.
Thinking of the CR2p as above or:
T52P or:
VS-TX or:
T7-2P
Looking for input on 20 inch off-sets and which rims would look good on the GSF. Obviously the 2P is cheaper than the 3P and will make a difference also.
Some of the wheel faces are more concaved will equal to lesser lip, and I love the JDM bigger lip if possible.
I have been doing some extensive research and finally decided to go with the work VS TX with a local vendor, they will also do some physical measurements for me also to double check.
I find the work T5R 2p and the workXvossen vws-3 doesn't match the large GSF. Love those designed but I think it matches a smaller car. Below are some pictures of the possible rim/color on my blue GSF.
work VS TX
I e-mailed Works USA and found the following info for a stock height GSF:
Standard fitment on GSF with VS-TX would be:
20x9.0 +29 L-Disk Step Rim Front
20x10.5 +37 H-Disk Step Rim Rear
WORK VS-TX 20x9.0 +29 L-Disk: Lip Size 45mm
WORK VS-TX 20x10.5 +37 H-Disk: Lip Size 70mm
Front: 255/30/20
Rear: 275/30/20
They also told me that the center is cast but the barrel is stamped...? I wonder if that means forged, spun cast, or cast...
If the barrel is spun cast or forged then I like them.
