GSF alignment specification
Old 10-16-19 | 09:32 AM
na1ddo's Avatar
na1ddo
Default GSF alignment specification
Howdy all,
I couldn't find any information on what the stock measurements for specifically the camber on the GSF is?
Are the stock arms adjustable in any way to reduce camber?
I feel like if I reduce the camber a bit, it would prevent debris from hitting the side of the fenders in the front/rear. That, or I need to start looking for mudguards for the car.
Hope someone has more insight on this!
Thanks!
Old 10-16-19 | 01:48 PM
Teutonic's Avatar
Teutonic
I think the specs are around here somewhere, but I wouldn't adjust camber for rock chips---I'd go with some type of mudguard. Something like this if that's what you're looking for:
https://www.clublexus.com/forums/gs-...s-install.html
Old 10-17-19 | 03:22 PM
lobuxracer's Avatar
lobuxracer
Tech Info Resource
There is nothing adjustable on the OEM suspension except toe. No camber, no caster, nothing but toe.
Old 10-17-19 | 04:04 PM
na1ddo's Avatar
na1ddo
Good to know. Thanks for the responses. I won't be paying my alignment shop a visit then.
Old 10-24-19 | 12:08 AM
Jeff Lange's Avatar
Jeff Lange
Keeping it Real
As was said, can't adjust it, but here are the specs if you're interested.
Front: -0°28' +/- 0°45' (-0.47° +/- 0.75°)
Rear: -1°16' +/- 0°45' (-1.27° +/- 0.75°)
There's not a lot of camber in the stock setup, at least in the front.
Jeff
soepyanf (10-26-19)
SdLS400
06-17-13 01:02 PM
kamikaze04
Suspension and Brakes
07-30-12 01:46 AM
dRo15
02-26-08 11:34 PM
ShaneC
02-24-08 06:18 PM
One HoT
11-07-02 02:20 AM
Quick Reply: GSF alignment specification
