gsf alignment and steering ratio
So I switched tires side to side, car still pulled to the right.
Got alignment done by a Toyota master tech and as soon as we untightened the LCA lower bolt, there was some sound/movement indicating stress release at normal ride height. After all bushing were 'reset', here are the alignment numbers before/after:
The caster was in-spec. Maybe the prior machine was off, or maybe resetting the bushings had something to do with the caster now being in-spec (7.7-7.8 vs 5.0-5.2).
LHS was toe'd in and the RHS was toe'd out like you suspected.
The toe/camber/caster are all reasonable now but the car still pulls right! Not sure where to go from here.
Tech Info Resource
If it were mine, I'd raise it a little. Over -2.5 and you start to get genuine camber wear, and other issues related to it like tracking in a straight line and braking effectively. Yes, race cars run way more camber, but they're not on street tires and the drivers already know the car won't be easy to drive.
OMGV8 (09-07-22)
