AFE Takeda Intake vs KN Drop-IN
I would like some advice/opinions as I cannot decide. Which is the best way to go...
K&N drop-in /OEM Filter or AFE Takeda Intake WET FILTER ? Comparing these 2 setups......is one better than the other all the way around?
I was told the AFE Takeda is ONLY good for High end (freeway) and that I would lose on the low end.
I have both ready....to install.....
I appreciate the responses and thankyou in advance.
designo (06-04-20)
The Takeda because the cone offers more filtering area. The AFE filter is available in both wet or dry versions. Which one do you have? As far as wet filters go (the Wet AFE and the K&N) many members on the forum are opposed to their use because of the potential to foul the ECU. Personally When I had my ISF I ran both (K&N panel and AFE wet in my Takeda). I never had issues and I have used K&Ns in my earlier cars without issue. If you're smart with the reoiling process you should be fine.
With that said, I would recommend you stay with a dry filter because today they're pretty good. When I change the two panel filters on my LC I will be going with Wix filters.
Lou
Lou
Lou
Lou
^^^^Then the Takeda, but when you reoil be extremely careful to not overoil and let the filter drain over night on a newspaper. Do NOT drive for 24 hours after installation! And No - you will not lose anything in the low end
Lou
Lou
RC51TOFUMA (06-03-20)
I think part of the problem is that when the secondary butterfly opens on the GSF, it pulls in engine bay air. Without an IAT in that area, it's hard to say whether or not it is bad, but the intake pulls in cold air from 0-3500rpms from the front grill area and when that butterfly opens it's pulling in cold from the front and probably hotter from the engine bay. I installed the RR-Racing heat shield that requires a slight trim of the seal area near the passenger side fender area. This will help the engine to pull in more cooler air from the fender after 3500rpms.
That said, a combination of the Takeda intake and RR-Racing heatshield may be the best as you increase filter area over the K&N drop in and hopefully reduce intake air temperatures by allowing cooler air to be sucked through the fender when the secondary butterfly opens at 3500rpms.
STeve
STeve
STeve
STeve
Can anyone confirm at all ? I looked at the installation videos for the Takeda Intake. It does Not show that this intake disables the butterfly flapper that you are referring to. Or does it ?
Can anyone elaborate ?
Steve
I had the BMC drop-in filter on my car previously and didn't feel anything honestly.
I then installed the Takeda (Cone filter DRY ) type in my car and immediately felt the initial throttle response.
I specifically installed for the look and sound factor only. From experience over 20 years, I can assure you that an open type filter element system on a naturally aspirated V8 will lose you power. Mid-range and top range will be compromised. I also coupled the system with the heat shield to avoid sucking engine compartment air in the secondary intake.
A wet type filter will most certainly over time, foul your MAFs.
Just make sure upon installation, you double-check to see if the cone element is not impeding the operation of the second flap. Otherwise, you're gonna hate your car's performance.
NOTE:
WITH AN OPEN TYPE AIR INTAKE SYSTEM, YOU WILL LOVE YOUR CAR IN THE WINTER AND HATE IT IN THE SUMMER.
DON'T TAKE MY WORD FOR IT, TRY IT YOURSELF.
NOTE:
I live in a very warm, humid and dusty country 9 months of the year
