Cool. See, you gotta try to fit it in there. And the plugs for the front doors are attached to the door, whereas the plugs for the rear doors are attached with the panel. Seems like a lot of work in that tight space, but if there's a will there's a way I guess.
I think for the RGB kit that guy had to run wires from all the doors to a central controller, so a lot more work. It's a tight fit to run the wire through the door panel gasket to the inside of the car. I've been in my friends BMW and he has the option to change the colors for the interior lighting but he leaves it on blue because it looks the best.
