Best way to Buy a Lexus GS F
#47
GsLex02 (10-19-20)
#48
I really want to stick with a CPO but damn it’s hard searching nationwide for these cars at a dealer
#49
get it.....its off the list. If $$ is no object then you'll be fine. If your trying to be savvy then you may need to be flexible
#50
not looking for an argument here or to mislead anyone but I do believe that a CPO is in fact transferable. One time only and only private seller to private seller. See my attached pic. I'm on my 3rd LCert car, this one being a GSF and it does say its transferable. Obviously a quick phone call to any lexus dealer will clear this up. Best of luck w your search for a GS F. My advice.... try not to pigeon hole yourself and only be willing to accept certain spec cars. If you hate molten orange then I get it.....its off the list. If $$ is no object then you'll be fine. If your trying to be savvy then you may need to be flexible
"The coverage under this warranty begins (a) at the expiration of the Basic Warranty, or (b) at the vehicle purchase date, whichever occurs later, and remains in effect until the earlier of two years, or the date on which you transfer your Lexus to a subsequent owner, whichever comes first (the "Warranty Period"). Mileage is unlimited. This warranty is not transferable to any subsequent owner. THIS WARRANTY IS NULL AND VOID IN ALL RESPECTS IF YOU PURCHASED YOUR LEXUS FROM ANYONE OTHER THAN AN AUTHORIZED LEXUS DEALER."
Though it says this only applies to cars purchased after January 6, 2016, so the terms may have been different before. Am I missing something?
#51
So I just checked out all my paperwork. The only variable that may be at play here is that I ( during haggling) was able to have my L cert extended for an additional 60 months pro bono. Possibly because of that extension different rules apply. Im not quite sure but the L Cert booklet in my glove box that I just received a few months ago clearly says it's transferable 🤷♂️.... we need to get to the bottom of this 🙂
#52
Good Morning. I have found a GS F on Carvana, and I have it on hold for 72 hours. Anyone have any thoughts on the price? Also here is the VIN, JTHBP1BL6GA001027 I checked Lexus and it appears to have been serviced at the dealership but it has had 3 owners. Looking for opinions. Not a fan of the black interior, but I guess I can live with it If the deal is right. Appreciate your help everyone
#54
I’d hold out for a one owner but if this car has a solid service hx, new tires and new brakes $47k may just be where you are bc these are getting hard to find. Other thing to check on service hx is to look for when brakes were done and how many miles between brake jobs (gives you an idea of how hard it was driven). If tires were replaced find out brand (car comes with Michelin pilot sports). If previous owners were getting tires and brakes done at dealer, it was prob well taken cared of. I’m thinking this car should be $45k, prob has a $41k trade in, but if services are done, brakes and tires are oem and new, then $47k isn’t too bad, but this isn’t a phenomenal deal.
id also check how much you’ll put into this car for 35k, 40k, 45k and 50k miles. Check service manual to figure out if any of those are major services or pay $200 and do a PPI at a Lexus dealer. Everything should be good until 60k service which is still 2 yrs away for this car
as a point of reference I have a 2016 with 21k miles and have yet to do brakes or tires.
#55
the year, mileage and price are spot on. I think that's a good deal. The 3 owners on the other hand would have me a bit concerned. I'd run a carfax, autocheck and i know you put it through lexus drivers to do some Sherlock Holmes type investigating. Where was it registered? I've read that some GSF's primarily in the south ( Texas and AZ) were used for track days for journalists to test drive and consequently write up an article. Obviously those cars were driven HARD before even having a chance for any break in period. I know what its like to really want the GSF and how hard it is to find one. Just did all that tbus past summer. Can you see the car in person? Test drive? Not sure if that's a thing with carvana. Best of luck with making your decision. Ultimately its a high end toyota and I would bet it'll be great. But its a big decision. Due diligence is recquired.
#56
According to Lexus Driver, the brakes were done in 7/2018 at 21506 miles. In October of last year at 30919 miles, it appears there was something done with the brakes, but I do not understand the lingo.
"Service: OTHERS, REPLACED WEATHER STRIP
description: OTHERS, REPLACED WEATHER STRIP ~|~CUSTOMER STATES DRIVER SIDE WEATHER STRIPPING LOOSE ~|~FOUND DOOR EDGE WEATHER STRIP FALLING OFF DUE TO LACK OF ADHESIVE ~|~OTHERS, REPLACED WEATHER STRIP
Service: PERFORM MAINTENANCE INSPECTION
description: PERFORM MAINTENANCE INSPECTION ~|~CUSTOMER STATES PERFORM MAINTENANCE INSPECTION ~|~PERFORM MAINTENANCE INSPECTION ~|~PERFORM MAINTENANCE INSPECTION
Service: R AND R FRONT AND REAR BRAKE PADS
description: R AND R FRONT AND REAR BRAKE PADS ~|~CUSTOMER STATES CONSTANT BRAKE NOISE IN THE FRONT INSPECT AND ADVISE ~|~LSB001316 CONFIRMED BRAKES SQUEALING UPON SLOW STOPS, CUST WANTS LSB PADS ~|~R AND R FRONT AND REAR BRAKE PADS"
It also appears that something was done just last month to the front camera, not sure what this means either
GUESTS REQUESTS TO REPLACE FRONT WINDSHIELD WITH OEM PARTS AND RECALIBRATE RADAR CRUISE CONTROL FRONT RECOGNITION CAMERA ON SEDANS ~|~REMOVED AND REPLACE FRONT WIND*****************TECH 532 REMOVED AND REPLACE FRONT WINDSHIELD 2.0HRS************** TECH 972 PERFORM FRONT CAMERA RECOGNITION AND ROAD TEST 3.0HRS*********SHIELD PERFORM FRONT CAMERA RECOGNITION AND ROAD TEST ~|~36388 REMOVED AND REPLACE FRONT WIND*****************TECH 532 REMOVED AND REPLACE FRONT WINDSHIELD 2.0HRS************** TECH 972 PERFORM FRONT CAMERA RECOGNITION AND ROAD TEST 3.0HRS*********SHIELD PERFORM FRONT CAMERA RECOGNITION AND ROAD TEST REMOVED ANGUESTS REQUESTS TO REPLACE FRONT WINDSHIELD WITH OEM PARTS AND RECALIBRATE RADAR CRUISE CONTROL
#57
#58
If it was me I'd be on the phone with the dealer. I always find them to be helpful. Ask them whatever ?'s you wish. And even if you don't live in that area I'd tell them your wanting to buy the car and your looking to build a relationship w them for all future services. They'll bend over to answer all your questions with the hopes of earning your business. I was personally relentless and even got to communicate with my GSF's original owner! How cool is that. The dealer provided my cell to the previous owner. He reached out to me and answered all my questions. Just be relentless.
#59
First owner was in Nevada, owned it a year and placed 11,812 miles on it. It was then sold as a CPO in Nevada and appears to have stayed there for an additional 2 years and 5 months with about 9,771 miles per year. 3rd owner is interesting, had it 8 months, but only placed 36 miles on it? Not sure what to make of that. Odometer reading was reported in California and then the next entry is not until August of 2020 when a title was issued in August, then it ended up on Carvana's website the other day. They deliver it after it is fully purchased and you get a 7 day test drive period, and you can return the car if you want too.
