Considering buying a GS-F. Common maintenance/failure items?
Considering buying a GS-F. Since it'd likely be out of warranty, wondering what the common failures are and maintenance items to look out for? This is both for when buying and to get an idea of costs over time during ownership.
From what I've seen brake pads/rotors can be expensive at the dealer, but what else?
Rapidly approaching 80k miles on ours. Small issues - mirror motors on both sides have had issues with horizontal movement. First the driver's (left) side, now the passenger's (right) side. Easy enough to apply voltage directly to the motor and get it spinning again, but why should I have to?
HVAC control servos have been known to have issues, L-SB-0001-21 covers this for the affected model years - this is not unique to the GS F, there are many models impacted by this LSB.
OE pads and rotors are pricey. Aftermarket isn't and will work fine for a normal street driven car. If you're planning to hit the track with it, expect to pony up serious money for consumables. This car is heavy and will eat pads and rotors for lunch at the track.
ScatmanATL (03-07-21)
With the BBK the pads/rotors/tires will probably be the biggest cost. I've put 15k miles on mine so far and so far just oil changes. The peeling clear coat on the carbon fiber dash pieces is a cosmetic issue but not really necessary to repair. Some have reported issues with a cracked headlight, which I do think would be an unexpected expensive replacement. I did see some mentions of the glass roof shattering by itself but it seems to be the exception rather than the rule.
The OEM carbon fiber is super expensive to replace. The spoiler alone is $2500-$3000. The whole front grill/carbon comes together so it’s expensive.
Avoid dealers for brake jobs. I got quoted $1600 just for front pads/rotors. Go aftermarket or eBay + Indy shop.
I’m on that setup for 15k miles and zero issues with non-track use. Going to try getting the OEM brembo rotors off eBay next time.
I called up R1 Concepts and got their “geomet” rotors for my GSF. They gave a discount and I got front+rear rotors for around $470. Bought front+rear project Mu pads for $600. Rock Auto was $50 (shipped) for sensors. R1 Concepts can hook you up with everything you need if you want their stuff.
Do you feel a significant difference in braking performance from stock? Is there a big difference in the initial bite? I do not plan on tracking the car at all, so track performance is not a priority to me. I noticed that the brakes on my RC F have a crazy strong initial bite when you get into the brakes.
The project Mu / R1 concepts setup I have does not have the bite like the OEMs. I’ve heard TOMS have an OEM-like bite so I’m looking to get those next. Still great though. I’d give the brembos an A and the Project Mu’s a B+/A-. The pluses for me are (1) almost no brake dust, (2) almost no brake squeal, and (3) longevity seems better for daily use.
I bought rotors and pads from Rock Auto. Stupid cheap. Work just fine for my use case. There's no reason in the world to spend a lot of money on brakes if you don't track your car.
FWIW, my IS F has RB two piece rotors from Figs with Project Mu HC+800 pads all around. They're great for the IS F's use case, but the rotors were $2k by themselves.
