Service department disappointment
Tire pressure was in the high 20s so as I just happened to be passing by the dealership, figured I'd stop by for a top off. The TMPS sensors were not showing any alerts. While I was there, I also asked if they could check the tire tread. Well, a TMPS sensor happens to fail after the fill one of the tires - what are the chances? Seems funny to me. Now none of the readings are showing and I have to pay ~$400 for a replacement.
On the tire tread, they said the rears may need to be replaced soon. They didn't provide me with any indication of urgency, just a heads up. Well, I haven't driven the car since I got home and there are wires showing in the tires. Question for you all - is that not a severe issue that is dangerous for me to be driving on?
Are these issues I should escalate to the service manager?
Thanks in advance!
Thanks in advance!
Tech Info Resource
Wow. This is just one reason I don't do dealer service. You could buy four new TPMS sensors for less than $100 from Rock Auto (I did for my IS F). I am amazed they let you leave with steel belts showing. That's a huge liability for them.
It's not impossible to drive on corded tires, but it's not recommended either. I drove home to Atlanta from Kershaw, SC on this tire after a track weekend.
Reset tpms? Might help - yes pls change yr tiresResetting the Lexus tire pressure sensor is a quick procedure that only takes a few minutes. This way, you can get back to cruising the town in little time.
In order to the reset the tire pressure sensor inside your Lexus, you’ll want to complete the following steps:
- Fill the tires to the appropriate air pressure. You’ll want to do this when the tires are “cold” or when the vehicle has been sitting for at least a few hours.
- Turn the engine switch to Ignition ON mode.
- Use the arrow keys to filter through your vehicle’s settings on the multi-information display until you see the “TPMS” screen.
- Press and hold the button that looks like a black circle until the tire pressure warning light blinks slowly three times.
- Wait a few minutes, and then turn the engine off.
i remember freaking out when i saw my front inside thread on ISF like this. Had about 20k miles in the car.
is this just because if a bad alignment?
Tech Info Resource
UZ214 (11-09-21)
Schpnhauer
RX - 3rd Gen (2010-2015)
12
05-30-11 07:47 AM
