Exhaust and brake pads questions!
No one will like this, but I run Powerstop Z23 pads from RockAuto on the wife's GS F. Got Centric rotors from RockAuto too. They work perfectly for her purposes and they're stupid cheap. They are NOT low dust, I'd rate them pretty much equal to the OE pads except they don't wear the rotors anywhere near as quickly as the OEM pads do. I put new rotors on the car at about 40k miles, both front and rear. We are at 93k now, and the rotors are still doing fine as are the pads. I have rotors and pads sitting on the shelf in anticipation of replacement, but they're lasting a lot longer than the OEM parts did. From a performance perspective, the Powerstop pads feel almost identical to the OEM pads. I've never tested their fade resistance except when I bedded them. This is for a kid hauler and grocery getter, not a track day at all. That said, they really are almost indistinguishable from OEM in performance on the street.
The only place I’ve been able to find brembo rotors is eBay and that’s dried up a lot it seems.
NinjaNap (01-27-22)
Question for you - are you getting Centric or Dynamic Friction rotors from rock auto? In the two years I’ve owned my car I have never seen them sell brembo but hear people saying they got brembos there?
Take a look at EBC’s brake pads, especially the Yellow Stuff. They can be had for far cheaper than the other suggestions, and will perform quite similarly to the stock Brembos. If you’re not chasing peak performance, you can get a bit of bang for your buck.
If your Brembos have good meat on them, I may be interested in purchasing them.
Maybe someone can chime in - but I’ve heard Toms are the best for squeal and dust and to steer clear from Endless pads because they are crazy expensive and they squeal really bad in addition to dust (could be track pads?).
I’ve been running the Project Mu NS pads for 40k miles. They squeal bad until they’re hot but even then they still squeal coming to stop signs and lights. Not as bad as brembos though. Dust is still minimal.
The pads that most are recommending are track or spirited-driving oriented pads and are (typically) semi-metallic (which typically dust heavily). If that’s not what you want, just find a set of ceramic brakes with low-dusting properties. I’ve given you some examples, but there are plenty out there. You can find a set just fine under $150.
Powerstop Z26: https://www.powerstop.com/products/
(Amazon; this link is front only): https://www.amazon.com/dp/B08P5MBSQZ...ws_feature_div
I just ordered a set of Z26 for my IS F. I bought race pads when I replaced the discs (running Racing Brake 2 piece) and have been running them, but they're too noisy at low speed on the street. People around me don't like the way I need to stop to make them quiet. Tired of the hard grinding sound of race pads when they're cold, and the high wear rate on the rotors because you can't keep a transfer layer on them with street driving. I believe they'll be just fine for daily driving, and I'll put the race pads back on the shelf for the next track weekend.
