Vehicle height problem -Variable suspension type
Also check to make sure the spring is sitting on the perch correctly on the side that is higher.
Steve
Steve
This definitely seems odd. Especially since the Variable Suspension is only for adjustable damping I believe, so height should not be effected by that. I think you might have some frame damage or something else going on.
How bad was the accident?
Get some coil overs and adjust height, problem solved.(cheap) route.
it’s probably your suspension and or frame which is off. I would just bug the insurance to get it addressed since it’s not factory spec
