Mirror Motor failures
Old 06-24-22, 01:21 PM
lobuxracer
Tech Info Resource
lobuxracer's Avatar
Received 4,010 Likes on 2,429 Posts
Default Mirror Motor failures
I am curious if I am the sole owner who has had the horizonal mirror adjustment fail on both left and right mirrors. Sort of glad for the extended warranty the wife insisted on buying because it covered it, but now I'm wondering if I need to be ready to replace the motors at some point in the future, and with the GS being discontinued, who knows when certain things will start popping up E coded.
So - BOTH left and right mirrors lost horizontal control. I'm also wondering if this isn't similar to the lock motor problem. Inevitable and can potentially be fixed very cheaply.
Old 06-26-22, 02:00 PM
mr2dave
mr2dave's Avatar
Have not heard of that one yet Lance.
Old 06-27-22, 04:24 AM
JColeGSF
JColeGSF's Avatar
No issues with mirror motors yet. Car has 22k miles. What does E coded mean?
Old 06-27-22, 11:48 AM
lobuxracer
Tech Info Resource
lobuxracer's Avatar
When parts are no longer available from Toyota/Lexus, they are E coded. As a Supra owner I am very familiar with this problem.
Old 06-28-22, 09:01 AM
bob256k
bob256k's Avatar
I have had my passenger side on my GS350 fail, was replaced under warranty. $1400 cost to the dealer, I paid nothing, they just replace the whole mirror. I had it set to tilt down so I could see the curb whenever I reversed , and I guess after so many years it just gave up. I no longer have it set to do that.
Old 06-28-22, 09:03 AM
bob256k
bob256k's Avatar
Hopefully it will take a while for the GS to be E-coded (TIL), since the IS500 and other Lexus seem to share some parts.
lobuxracer (06-29-22)
Old 12-03-22, 12:57 PM
shenry500
shenry500's Avatar
You're not the only one to have the problem. 16 gsf with almost 50k miles. Garaged. I found a thread on the gs350 forum claiming it can be fixed by taking apart the motor and cleaning off the corrosion with a brush. I'm about to try that and will update if it works.
Side mirror motor fix - ClubLexus - Lexus Forum Discussion
Old 12-03-22, 06:20 PM
lobuxracer
Tech Info Resource
lobuxracer's Avatar
That's a great thread. I took the part number from the motor, and you can get a brand new motor for less than $5 from a number of Internet retailers. Glad to know the motor isn't really toast inside, but it's a shame they don't seal them better to avoid the problem all together.
shenry500 (12-12-22)
Old 12-12-22, 03:55 PM
shenry500
shenry500's Avatar
Weird. I couldn’t find any motors online from searching the numbers. I did however find a clublexus Russia post that seemed to be similar theme
Old 12-13-22, 10:33 AM
lobuxracer
Tech Info Resource
lobuxracer's Avatar
This is a big help in understanding what we're looking at: https://www.mabuchi-motor.com/produc...ignations.html
This listing is also very helpful: https://www.aliexpress.us/item/2255800624865586.html
It would be interesting to see if there is an equivalent Vietnamese site since these motors are made in Vietnam.
shenry500 (12-18-22)
Old 12-13-22, 01:07 PM
VenomF
VenomF's Avatar
This is unfortunate to hear. Just to be clear, is it the horizontal fold-in mechanism or mirror horizontal adjustment that has failed?
One time I was working on my side mirrors and had to turn it past its normal orientation. I didn't place the mirror back into its operating position, accidentally pressing the lock button and it tried folding the mirror in, making a spring snapping sound.
At this point, the mirror spun freely and i was worried the spring inside had popped something out of place.
I folded the mirrors in manually, turned the car on and used the folding feature button to reset the mirrors by itself, which fixed the issue.
Old 12-13-22, 02:14 PM
lobuxracer
Tech Info Resource
lobuxracer's Avatar
These motors position the mirror vertically and horizontally. Both of my failures were horizontal motors. Vertical kept working fine. Lexus bought new mirrors under warranty for me, but I suspect they will fail again, so this motor info is really helpful.
I've never had an issue with the folding function.
Old 12-13-22, 05:54 PM
GregCanada
GregCanada's Avatar
On my 2013 gs350, the passenger side horizontal stopped working a few years back, driver side this year.
I pulled the mirror off, sprayed a ton on electrical contact lubricant wherever i could. then put the mirror back on. moved it back and forth for awhile. Then they started working again. Its like they were a bit seized (because the vertical moves everytime you put into reverse, it gets action, where horizontal does not... may be a good idea to make it move a bit to keep from freezing up?)
May not work for everyone, but its worth a shot. Even try just moving the mirror back and forth to see if that gets it moving.
Old 12-18-22, 02:46 PM
shenry500
shenry500's Avatar
Gonna order a few of these. Fingers crossed. MABUCHI FC-140SA DC 12V Car Door Lock Actuator Rearview Mirror Repair Motor | eBay
I took mine apart and swapped the motors, which caused the opposite action to stop working. After narrowing it down to the motor itself I took it apart and cleaned it with sandpaper and alcohol for the grease. Nothing changed so hopefully these shipped from china motors will work!
Old 01-01-23, 02:37 PM
shenry500
shenry500's Avatar
Fixed with this motor. Link to my write up and pics toward bottom of thread (#21)
https://www.clublexus.com/forums/gs-...tor-fix-2.html
lobuxracer (01-02-23)
Quick Reply: Mirror Motor failures
