Climate control error message
![](https://cimg2.ibsrv.net/gimg/www.clublexus.com-vbulletin/2000x1504/3635f120_96ef_461f_8786_d16a869bba74_2b291b32a8a9c6d9aa05cfbb1c40052781cd3c0b.jpeg)
Got this scary message on my gsf today. The ac/heat was working but the display showed this message. Turned the climate control on/off manually a couple of times and it went away. Anyone else encounter this message on their car? I assume regular 4GS shares the climate control display with the GSF,
Tech Info Resource
There's an LSB for the HVAC in the 2016 and 2017 models. L-SB-0001-21 HVAC Servo Motor Malfunction. It includes a software update.
Symptoms are:
Uneven temperature or air flow between the vents.
Little or no air flow from the vent(s).
Improper MODE control function.
Potential DTCs for this are:
B1441 – Air Mix Damper Control Servo Motor Circuit (Front Passenger Side Lower Air Mix).
B1442 – Air Inlet Damper Control Servo Motor Circuit.
B1443 – Air Outlet Damper Control Servo Motor Circuit.
B1446 – Air Mix Damper Control Servo Motor Circuit (Driver Side Lower Air Mix).
B1447 – Rear Air Mix Damper Control Servo Motor Circuit.
B1448 – Passenger Side Face Servo Motor Circuit.
B1449 – Rear Air Outlet Damper Control Servo Motor Circuit.
B1453 – Driver Side Air Outlet Damper COOL Control Servo Motor Circuit.
B1454 – Passenger Side Air Outlet Damper COOL Control Servo Motor Circuit.
B1455 – Driver Side Air Outlet Damper FOOT/DEF Control Servo Motor Circuit
Symptoms are:
LS Boy
SC- 1st Gen (1992-2000)
22
07-13-05 07:14 PM
