Electric Trunk Modification?
5th Gear
In the YT video below, you will see that the euro GSF has an electric trunk that powers up and down. Having a LS, I’d love to know how to make the modification on my 2020 GSF.
I’d be curious if anyone has done this mod and has a parts list.
https://youtu.be/j1XLud6OWbY
CMK (07-14-22)
The left side hinge from a 2018 GS FSport with the auto trunk feature
2018 GS FSport and up trunk harness, cause the GSF have led rear lights
Trunk actuator with piggy harness plus 3 bolts to bolt on car
Trunk manual switch with casing and 2 10mm bolts
Tap into the wire harness after you remove the trunk multiplex unit/trunk module on the GSF.
I have all the parts but I just don't have the time to install it. I did a post on the rear power sunshade which I installed and rear door shades.
DavidL (08-09-22)
