Ambient Door Lights
I have been considering doing this door lighting mod to my car. I love the way it looks once completed, but I'm a little intimated by soldering wiring together since I have zero experience doing it. After watching this video at the 11:26 mark, the led is shown. I figure, why not just try to upgrade the LED since it would be plug and play. My question is, does anyone know what LED bulb size this is? Any recommendations where to buy replacement LED's?
Tech Info Resource
Soldering on a wiring harness is a bad idea. You'd be way ahead to crimp instead of solder. Way easier too. I have extensive experience with both methods, and have been to high reliability soldering school while in the Air Force. If solder were better, I'd say so. It's not. I'm a huge fan of a bare crimped connection with a shrink tube cover proving insulation. You can even color code it so it's easier to troubleshoot.
Might be interesting to experiment with a higher wattage LED before going to the strips.
Tech Info Resource
I haven't pulled it apart to see what is there, but in the video the LED appears to be on a small circuit board. It might be worth looking at replacements one could solder onto the board and make more light than the OEM solution instead.
littlenick
04-06-10 07:47 AM
mikes rx
03-25-09 02:18 PM
