Mid Priced Rotor Selection
Hello all, I'd like some help selecting slotted rotors. I need to change out front pads and rotors soon, so I currently have R1 Performance Sport series pads. (I'm guessing they're same as DFC Active Performance pads)
I daily drive my car with occasional spirited driving, and maximum 3 canyon/mountain runs a year. I'm looking for low noise and less brake dust, but not a necessity.
I have three rotors in mind.
Centric Premium Slotted OEM Style
Brembo Slotted OEM
Dynamic Friction Hi-Carbon Alloy GEOMET Slotted
Any experiences with these or major differences between the three?
Thanks in advance.
Brembo Slotted OEM
Thanks in advance.
This is in the ISF Section - Similar braking system - You may find this thread useful:
https://www.clublexus.com/forums/is-...struction.html
Brembo Slotted OEM
Thanks in advance.
Brembo Slotted OEM
Thanks in advance.
I also don't know what rotors were installed on the front (if they were every replaced) so I want something that will last with spirited driving.
Tech Info Resource
People overthink rotors all the time. I get them from RockAuto, and I'm currently running Centric on the GS F with Powerstop pads. Works just fine for daily. Not sure how much of a lunatic you are on canyon drives, but the Z24 pads on the car now are reasonably good and reasonably cheap from RockAuto.
Only a fool turns rotors these days (or shops who are looking for a profit center). There's not enough material to make it worth the effort. If the rotor is that bad, just replace it. They're plenty cheap unless they're two piece rotors.
FWIW, I run two piece slotted Racing Brake rotors on my IS F. I drive it very differently from the GS F, and I have tracked the IS F using track pads, and I was able to completely fade those pads with VSC turned on. I've also run track pads on the street, but I got really tired of the noise and the dust was annoying until I got a subscription hand car wash service.
