ls Motul RBF600 brake fluid compatible with 2016 GS F?
I know it might be overkill, but I've got a couple of extra bottles of Motul RBF600 from my other car on the shelf. Just want to be sure I can use this on the GS F or is this not compatible? If not, what do you recommend?
I'm planning on doing my first track day in the GS F in a few weeks, changing pads/rotors at this time as well. Hence, I was thinking of what fluid to use.
Tech Info Resource
RBF600 is safe to mix. There are only a few that are not. Handy comparison chart here: https://www.lelandwest.com/brake-flu...ison-chart.cfm
If the plan is to do a full R&R, make sure you have a liter. 500cc won't be enough to do a full swap.
AdamKTexas (08-30-22)
In this case, what brake fluid do you all recommend? This will probably be the only track day on this fluid, for at least another year. Still recommend Motul, or is that overkill?
Tech Info Resource
I run Brembo LCF+ in my IS F, and Valvoline in the wife's GS F. Her car never sees track duty. Using that comparison chart, the ones that stand out for me are the Motul RBF600 and the ATE Typ2. Both have a high wet boiling point and a low cost per ounce. If money isn't the issue, then you can't be Castrol SRF for the amazing wet boiling point and stability. You'll find SRF in more professional racing vehicles than anything else. I would not recommend Brembo LCF+ for your use, it requires frequent maintenance because it is highly hygroscopic compared to most other brake fluids.
