Hi!
Can anyone help to understand how to connect my cruise control cables to the plug? Connector and colors are right here (there are 2 white cables, one goes together with yellow):
If anyone could take a picture of his/hers connector with the colors of the cables visible (showing which cable goes into which hole - that would be much appreciated!
Hi lobuxracer, thanks for the reply, it's a cruise control radar connector (88210-48071).
Btw, does it make a difference if I use 88210-48071 or 88210-48070? I've just bought a 2020 GS-f, after a small accident and someone ripped out the radar together with the connector and cables..
Thanks!
I can't speak to the difference between the 0 and 1 version, although typically it's a minor revision and usually interchangeable. Here's the wiring diagram for the US and Canada models, hopefully yours is the same:
Here's the pinout on the connector. Use the numbers above to map the wires to the right place on the connector.
