1st GSF with the valley plate leak?
I'm actually having this issue currently, my heater wasn't working until I filled up the coolant reservoir, which was pretty low. I also see the same pink residue near the bottom of the engine bay
NotnFsport (02-10-23)
It’s just a matter of time for all of us unfortunately.
Steve
Steve
Tech Info Resource
Already did this on my IS F. It's tedious but not terribly difficult.
My last GSF, which was totaled dec of 2022 had 85k miles. I had the pink residue and coolant loss since around 80k miles. Super glad i didnt have it done prior to it getting totaled, lol. My current GSF only has 35k miles. Not sure if i should flush the original coolant or not
Tech Info Resource
Over the years, ppl have argued replacing the pink stock coolant with the red as I assume they figured the pink interacted with the sealant in a negative way. That’s the only thing I could gather from different documents. Or it’s just luck of the draw if it happens or not
it comes with pink. Red is what ppl switch to. I also read somewhere that the red has less corrosive chemicals compared to the pink. There’s a thread on here where someone listed each chemical in comparison.
It's the chemistry, ALL OF THEM will wear and become corrosive.
This item used to be a 3yr/36k service item. All fluid becomes acidic over time when you heat and cool it against metal with organic materials.
Wanna skip the valley plate leak? Be agressive with the coolant every 3yr or 30k
Tech Info Resource
Except there's no indication of any corrosion when you reseal the plate. The inside of the coolant passages is perfectly pristine, AMHIK. Why is it some cars have the problem and others do not? I doubt it's coolant change intervals. The best test for coolant is to take your DVM and put the negative probe on the chassis and the positive probe in your coolant without touching anything else. If it's less than 0.5 Vdc, you're good. If it's more, it would be wise to change because your block is thinning.
I'd also bet the reason for the pink coolant is no different than the reason for the "lifetime" ATF fill. If you put your first change interval over 100k miles, the EPA gives you a pass. If it's less, you (as a manufacturer) have to pay to support managing the waste stream.
shenry500 (05-05-23)
Seeing these reports from people, I'm somewhat prepared for this to happen to my GS-F someday. But I just wanna know how do I make sure the dealership actually uses the correct sealant when they re-seal it? Do I simply just request them to use that specific ultra expensive sealant? How do I know they actually used it?
I rather not deal this myself, it seems like a mess and quite some work.
The TSB has the replacement sealant as the only option.
Steve
Steve
