GI: Poly bushings JZS147
Old 01-03-12, 11:09 AM
FIGS
The Maker
FIGS's Avatar
Default GI: Poly bushings JZS147
Hi guys, gauging interest in a poly bushing applications geared towards the JZS147.
Currently we can provide the following, just wondering how much interest there is and I will get them coming.
Front LCA (both eccentric and non eccentric)
Front UCA (centered only)
Front Tension arm ( caster #2 bushing with both eccentric and non eccentric versions)
Front steering rack
Rear toe link
Rear Traction link subframe and spindle side
Rear upper Control arm
Rear LCA shock mount
Rear LCA inner mount
Rear subframe
Rear diff pinion mount
Sway bushings for OEM
30mm front sway bar bushing
24mm rear sway bushing
Rear Crossmember restraint washers, to tighted the crossmemeber mount.
Reply with items in bold or just let us know, or if you have another bushing that you want to see also chime in.
thanks, Mike
__________________
Redefining Lexus Aftermarket Parts Since 2001
-- We are your Lexus suspension experts--
BCR - KW - PENSKE - OHLINS - HKS - GREDDY - STANCEPARTS
Links - Arms - SuperPro Poly Bushings - Solid Bearing Conversions - Motor Mounts
RB BBK's and 2P Rotors, G-Loc pads, Radium Fuel Systems
Custom Fabrication Design and Machining - Industrial 3D Printing - Laser Cutting
2018 USTCC Sportsman Class Champions - 2018 NASA ST5 National Champions
Old 01-04-12, 01:20 PM
kene
kene's Avatar
I am interested. But I think the biggest thing in this side of the forum is pricing.
This is just my opinion...I have no facts to support this.
If you don't mind, price wise what are some rough guesses?
As I have been very curious to see what a few of these may run.
Old 01-05-12, 09:11 PM
flybye
flybye's Avatar
I am certainly interested if the prices are FAIR
Old 01-05-12, 11:44 PM
FIGS
The Maker
FIGS's Avatar
Prices will be reasonable and it will depend on the complexity of the bushing. Standard LCA bushing for example will be around $90 for both sides, the eccentric version around $150 because it requires a specially machined crush tube.
Just give me some feedback.
Mike
__________________
Old 01-06-12, 10:31 AM
blklegend
blklegend's Avatar
Can you provide estimated prices for each component and also possibly 1 or 2 package pricing.
Old 01-06-12, 10:37 AM
FIGS
The Maker
FIGS's Avatar
Can you be more specific? I gave one example of the LCA for the front, the price varies on the complexity of the function and if it has a two sided fit, a press fit or if the material is injected into a press collar. Bushing bundles will have a discount of 5-15% depending on the number of pieces included.
If you have bushings locations in mind I can check then out and speculate on the projected pricing based on what we have already.
Thanks Mike
__________________
Old 01-07-12, 09:28 AM
kene
kene's Avatar
Those prices are not that bad at all, just activity on this side of the board is not as active as others areas. So I'm not sure how many would chime in on this deal.
Old 01-07-12, 11:27 AM
FIGS
The Maker
FIGS's Avatar
Well, I might just start with 2 sets of each and see how it goes. If there is more interest we can go from there.
__________________
Old 01-12-12, 07:15 AM
trd4life
trd4life's Avatar
Tein USA has a sells the complete line of JZS147 Superpro Poly bushings out of Australia I have a complete set front to back in my car. Not cheap though!
Old 01-13-12, 09:08 AM
FIGS
The Maker
FIGS's Avatar
Yes Tein USA has been a distributor for a few years but has not been focused on the market. We are focusing on which bushings are important and also working with Superpro directly to reprice the market if something is way off. We plan on becoming a central distribution hub for SP and also using them for our own internal developments on applications they do not offer.
__________________
Old 01-13-12, 10:24 AM
Johnny D
Johnny D's Avatar
Id be interested in this
Old 01-15-12, 08:06 AM
wilsonsan
wilsonsan's Avatar
me also so +1
Old 01-15-12, 01:58 PM
vtec-this
vtec-this's Avatar
caster caster caster bushings!!!! i need them so bad VERY INTERESTED
Old 01-15-12, 04:59 PM
Matador
Matador's Avatar
ugh, my bushings are worn to hell... so whats the ETA on this stuff
Old 01-28-12, 10:34 AM
redlinezak
redlinezak's Avatar
Do you offer anything for the JZS161?
Thanks
Quick Reply: GI: Poly bushings JZS147
