Loud Clunk when car is COLD.
Old 10-28-04, 12:06 PM
alexulan
alexulan's Avatar
Default Loud Clunk when car is COLD.
Only when the car is cold and on first application of the breaks. After you warm up no more noises. I don’t suspect that it’s the motor mounts because in N revving the motor does not make the sound. Only when applying the breaks. Could be bushing I guess.
Is this normal or not.
A lot of people have this noise and from searching the forum all you need to do is re-lube the break shims?
What gives and what do you really need to check?
Old 10-28-04, 04:25 PM
doug_999
doug_999's Avatar
The first time I hit my brakes - no matter what the temp, I get a loud clunk. Have had it since day 1. Told the dealer about it and they cut me off before I could finish telling me it is normal.
Old 10-29-04, 12:47 AM
rominl
exclusive matchup
rominl's Avatar
i think it's normal when the pad shifts a bit?
Old 10-29-04, 09:37 AM
alexulan
alexulan's Avatar
OK, If it's normal why did the car not make the sound for the first two years of use.
GO to the lot and test drive a new car.... Does it make the sound?
How does the dealer figure it's normal?
Old 10-29-04, 02:17 PM
doug_999
doug_999's Avatar
Cause Lexus Dealers don't know how to fix cars? Just my opinion of course.
Old 11-01-04, 09:50 AM
alexulan
alexulan's Avatar
OK, I no longer suspect that it is the breaks. The sound is there all day long mostly when changing directions. R to D or D to R not shifting but when stopping. Weight shifting to front or back.
This has got to be the Motor mounts or the suspension brace.
How much fighting am I going to do with the dealer because I have after market Rims, Shocks and Springs?
Anyone have pics of the place the where the break usualy occurs? I need to get this thing on a lift.
Old 11-01-04, 01:26 PM
racer_xxx
racer_xxx's Avatar
Took my GS to the dealer with the same problem (clunk while braking after going from reverse to drive) , they said it is normal.
I asked them why it haden't happened before and they said it becomes more noticable as the brake pads wear down.
Old 03-04-05, 12:15 PM
alexulan
alexulan's Avatar
Talk about ancient thread bumper.
Well I went back to my mechanic with the complaint and guess what,
He is like ohh I know It's normal no problem I'll fix it for you.
You guys were all correct.
It is the front Pads shifting.
You can't just drop the OEM Pads during the install and walk away.
They need to be adjusted (I think he pushed out the springs on the edges of the pad and filed a little piece on the edge of the Pad) well I have been driving it like a month and it's super quite.
I should have complained to him a lot earlier.
Yea it basically the guy doing the install taking shortcuts and not adjusting the front pads correctly.
I think it took him exactly five extra minutes a pad to adjust.
Don't do it right the first time make them do it over.
Luckily he is a nice guy and he didn't charge me a cent even though it has been over three months since he did the breaks.
rj12
09-01-15 08:40 PM
anewname
10-11-11 07:09 PM
Chris98vob
GX - 1st Gen (2003-2009)
12
12-29-09 11:05 AM
LilMan23
11-23-09 12:16 PM
underpsi
Performance & Maintenance
04-18-07 02:36 PM
Quick Reply: Loud Clunk when car is COLD.
