Radio Fuse Keeps Blowing... Help
Hi,
My radio fuse keeps blowing everytime I put in a new one. It blows the the climate control and then I cannot shift my car between park - drive without using the bypass the shift lock override. This happens even if I disconnect my aftermarket stereo. I cannot figure out why it doing this.
Anyone have any thoughts?
The best way to diagnose is to remove (or turn off) all the things on that fuse circuit.
Isolation method:
Then bring on line one load at a time and if fuse does not pop take it off.
Step through all loads.
Cumalative load:
Bring one item on line and keep adding the next till the fuse pops.
Peak Load:
Some circuits would draw more current when the signal level increase [aka amp].
So crank up the volume to increase load.
Salim
Isolation method:
Cumalative load:
Peak Load:
Salim
Mine is doing the same as well I disconnected my amp installed both radio 1 & 2 fuses didn’t blow but once I went to connect amp back fuses blew right away. I have a 06 is350 with mark Levinson system
91ls400own
07-09-09 12:57 PM
